Paper mache horn fabricator
#2 |
That should be pretty!
#3 |
I'll probably fabricate it from wire mesh and plaster--paint it with a pretty faux finish.
#4 |
very cool, please keep us updated on your progress
#5 |
I suppose I'd better take pictures...
#6 |
Speakerholic
Snail shell, I mean golden ratio yes?
#7 |
There was no intentional thought given to a golden ratio. The horn doubles its area every 36" or so. It's a curved horn, so the X axis doesn't apply for length. I moved the axis outwards to the 5/8-3/4 point and measured from there.
This is a 20hz horn meant to be loaded in a corner. Being truncated, it will require EQ, but seems like a doable experiment. Beings that there are no hard reflective angles, the output may register a higher frequency before tapering off. I base this notion on the fact that I can get fairly high frequency response from my goose-neck bass horn. John |
| double horn, bib or angular spiral horn? | testarossa2k | Full Range | 49 | 18th September 2011 03:03 PM |
| giant spiral horn | el`Ol | Full Range | 0 | 14th May 2007 08:31 AM |
| Spiral horn or TL? | Ang | Multi-Way | 4 | 9th May 2007 11:49 AM |
| Spiral horn math help wanted! | Spasticteapot | Multi-Way | 0 | 11th January 2007 05:27 PM |
| 3D spiral horn? | mark_titano | Multi-Way | 72 | 11th November 2005 02:11 PM |
| Page generated in 0.09476 seconds (77.40% PHP - 22.60% MySQL) with 11 queries |
