Pro Audio Equipment In the Home - Page 5 - diyAudio
Old 25th June 2006, 12:29 AM   #41
Very simple....
With XLR connectors short 3 to 1 in other words the inverted signal known as cold to the shield or ground. This will unbalance a balanced connection.
If dealing with a terminal strip make a short jumper to go from ground/shield to the minus or cold.
I suggest that attention be paid to proper grounding. As stated prior...there needs to be only ONE ground for the system otherwise the nasty gtound loop monster comes out to play.
There a a number of us with pro audio experience under our belts and I can say that we have all dealt with the noise issues have provided the solution based on experience and textbook knowledge.
Old 25th June 2006, 01:57 AM   #42
Ok so I just did exactly what you guys told me and now the problem is even worse. I think I'm giving up, I'll just return the stuff and stick to home audio with all RCA's.
Old 25th June 2006, 02:08 AM   #43
Send a picture or two of what you have done so we are clear on it
I'm sure we can resolve the problem.
Old 25th June 2006, 04:19 AM   #44
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Hey never give up. We are all here to help. Im running the same type of cable with aleph mini's into a passive pot and well no hum. I tried it with the op-amp Bufer too. I agree with the picture. Can you post any pics ?
Old 25th June 2006, 07:01 AM   #45
GM is offline GM  United States
GM's Avatar
Greets!
Maybe this will help: http://www.dplay.com/dv/balance/balance.html
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th June 2006, 12:27 PM   #46
BlackCatSound's Avatar
CARTRulz, disconnect the wire from pin 1 on the XLR end.
Old 25th June 2006, 12:31 PM   #47
Picture of terminal strip unbalance
Old 25th June 2006, 12:32 PM   #48
Home made unbalance cables
Old 25th June 2006, 12:34 PM   #49
One could also use standard XLR cables and leave the 1-3 jumpers on the terminal strip for unbalanced.
Old 25th June 2006, 12:38 PM   #50
I believe that BlackCatSound is pointing out that it is sometimes necessary to float the shield on one end of the equipment to eliminate the hum.
This practice will and does vary from consultant to consultant. Some favor lifting the shield on the input and some on the output.
Excess Audio Test Equipment 1audio Swap Meet 5 29th September 2011 09:13 AM
How to destroy your high-end audio equipment... HaflerFreak Solid State 109 27th May 2011 07:04 PM
Audio Equipment For Sale In Minnesota RMPEngineer Swap Meet 27 15th January 2010 02:28 AM
Unloading audio equipment Magnetmaz Swap Meet 5 18th October 2007 10:54 PM
fixing broken audio equipment cowanrg Everything Else 10 7th August 2002 11:38 PM
Copyright 1999-2017 diyAudio
