Old 30th May 2006, 06:22 PM   #1
Default Pro Amps vs. Home Amps
Hi guys,
I've heard a lot of discussion between the quality of home theater amps vs. pro audio amps. For something like 300 bucks you can get a 200 watt home theater amp, or you can get like a 750 watt pro amp. Now I've heard home theater watts referred to as "real" watts, and pro watts as "fake" watts, meaning that the pro amps have very little current, and if I'm correct, current is what we want to move these speakers. So, any thoughts/ideas? I'm asking becasue these Snell subs I have are rated at 600-1000 watts, and so I could either spend 300 bucks on a 200 watt stereo amp, and still underpower them, or i could spend the same 300 bucks on like a Behringer EP2500 that puts out something like 600 watts at 8 ohms.
Old 30th May 2006, 06:27 PM   #2
Send a message via MSN to xstephanx
the EP is a SOLID amp, and from what ive read it DOES put out rated power(depending on THD, a bit more).
Ive heard that usually prefer the sound of pro amps over plate amps for subwoofers, many people have said that they sound "cleaner" and "tighter"
also the eztra headroom on the EP would help.
BUT if this is for a HT setup, you have to know that the input sensitivity is LOWER meaning you might need a booster, although iev never heard of anyone having to resort to a booster(doesnt mean it doesnt happen).
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!!
EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!!
Old 30th May 2006, 06:30 PM   #3
pinkmouse's Avatar
There is a lot of snobbery regarding pro amps in the audiophile world. Yes, some do sound rubbish, and you have to be aware that quoted power figures are usually into 4ohm, but for driving subs a good pro amp is an excellent choice. I haven't heard the Behringer, as it is at the lower end of the market, but I'm sure it will be fine for you. If you want to spend a little more, look out for s/h kit like C-Audio, Crown, (not the Powerbase series), or QSC.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 30th May 2006, 06:37 PM   #4
Default Re: Pro Amps vs. Home Amps
Originally posted by CARTRulz
Hi guys,
You're completely the wrong way round, PA amps are 'proper' honest watts, and cheap home audio systems are the ones that specify 'imaginary watts'.
Any decent manufacturer though will only specify RMS watts, and it's that you should look for. Your home theatre amp is more expensive because it includes a LOT more, more channels, preamps, possibly a decoder as well, maybe even a tuner?.
I really don't think you need to run an EP2500 for a home sub-woofer though - it will certainly 'move' them, it might move them next door though!.
Nigel Goodwin
Old 30th May 2006, 07:58 PM   #5
Cool, thanks guys.
I actually have looked at Crown and QSC, they seem to be real nice. I'm not really worried about overpowering them, as they are Snell SUB1800's that go for about $2500 each brand new, and theyre speced at 600-1000 watts. I only ask becuause these are subs that are made to be "clean" and "tight" and arent really made for "boom box" applications, although they certainly have an immense of output. I was just curious about the power ratings and the power quality, as I'd probably go with a low distortion and "clean" amp over something thats gonna push the sub to lots of output but make it sound muddy.
Old 30th May 2006, 09:31 PM   #6
Cool, thanks guys.
The Behringer EP2500 is pretty well identical to one of the QSC models, as QSC haven't taken them to court?, it seems likely they both buy them from the same Chinese manufacturer?.
Certainly Behringer don't copy equipment to the extent of cloning, only the general idea and often the look! (which did get them in trouble with Boss).
Nigel Goodwin
Old 30th May 2006, 11:27 PM   #7
Relax is offline Relax  United States
Quick question, what would you guys think about this amp:
http://www.gemsound.com/products_amplifiers-pa4505.html
I can get it for under 300. Is there perhaps another amp that will do better similarly priced? 300 is my max, and I need soemthing like 700wrms into 4 ohms. (Well, I don't need that, but my subs would like it)
Thanks Ahead of time!
~Jerick
Old 31st May 2006, 11:32 PM   #8
Just some more info on the amp above.
I spoke with a customer service rep, and He said the amp uses a 250v 15 amp fuse. Does this work out to be a max of 3750 watts? So the numbers listed by the manufacturer are acceptable?
Also, can I expect the 800 wrms per channel on 110v?
Old 1st June 2006, 07:50 AM   #9
No, 1650W - your mains is 110V, on 230V mains the fuse would be dropped accordingly (perhaps 8A?). Fuses don't really have voltage ratings, it's just the voltage it's guaranteed to break reliably.
Yes, it'll be a 110V amp for the USA.
Nigel Goodwin
Old 2nd June 2006, 04:38 AM   #10
I concur. Line voltage x fuse amperage = potential wattage
110v x 15a = 1650 potential peak watts x amp efficiency (described by a fraction of 1)
fuse voltage does not matter in this equation
The PINNACLE of Home Brew Amps - Or Not... camshaft Solid State 14 26th March 2008 11:13 AM
Hypex Active Home 2-way amps CDubber Swap Meet 8 30th March 2006 02:01 AM
New home made S.E amps andrewe1 Tubes / Valves 5 4th February 2005 09:57 AM
Alesis reference amps in home stereo setup? djchase7 Solid State 14 28th December 2003 07:19 PM
Amps for Home Theatre bimbla Solid State 0 27th December 2002 04:14 AM
Page generated in 0.10220 seconds (87.67% PHP - 12.33% MySQL) with 10 queries
