Old 11th May 2006, 12:21 PM   #1
Default Dayton Titanic MkIII 15" sub bottom out
i finally got my sub from parts express.so far i'm not impressed with the sound quality.my 10 vifa sub blows the dayton away for sound quality.also it bottoms out too easily.i have it in a 3.75 ft3 sealed box driven by the ada1200.i have the amp on less than half gain.mind you it is pretty loud,but not what i expect from this sub.is the box too large,causing the sub to bottom out???or maybe it's the set up of the ada1200.anybody familiar with this amp
thanks
Old 11th May 2006, 02:26 PM   #2
Send a message via MSN to xstephanx
FIRST check placement.
second check for big leaks in the box
third start with your EQ flat, that could be wasting all your power up high or something.
fourth, calibrate the sub PROEPRLY, i know when i got my new sub which was ALOT flatter and extended deeper i percieved the bass as quieter, and made them +5db hot as compared to my names :O
make sure the spider is glued to the vc/basket assembly, theyve been having problems with that, if the spiderwasnt attatched to the basket that would make itbottom out REALLY easily.
try all that and see if it works
also, how big is your room, what are you using the sub for (movies? music? what kind of music?), if you have a big room a ported box may be better for you, since you can get ALOT more spl down low with a ported design(usually). and when properly implimented an overdamped poorted box can have VERY similar GD to a sealed box.
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!!
EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!!
Old 11th May 2006, 06:02 PM   #3
thanks for the advice.i have it placed against a wall need a corner.my room is 25 x 30.i got it for movies.can't bare to use it for music-sounds horrible.i want to stay sealed as i bought the adire ada1200 for this purpose.i think i need to figure out this the eq-ing on the sub amp more.i agree that i'm probaly wasting x-max on the really low frequences(below 20hz) than i don't need
btw:do you have the same sub
Old 12th May 2006, 02:30 AM   #4
i have a very similar one(atlas 15), mine has less power handling (rated 300rms, but ltso of car audio guys run em full tilt with 500 watts each.)and less xmax(only18mmwith atlas 15), in my box (6.5cuft tuned to 20hz)in my 12x10 room it gets LOW and peaks at aroudn 120db at 40hz(at 2m). not this is with 240 watts, and i have the advantage of a tiny room.
im surprised that your titanic isnt very loud. Maybe a ported box is in order fi its mainly for ht. For ht you usually want a house curve anyway so that those low frequencies really stand out and shake you around.
search google for a program called WinISD pro beta(alpha maybe?), download it, put in your driver paramenteres and try and model out an SBB4 and EBS3 design.
Old 14th May 2006, 03:53 AM   #5
Paper mache horn fabricator
carpenter's Avatar
Default One 15inch subwoofer for a room that big?
Hi chainenoble,
You say your room is 25 x 30. It that in feet? How high are your ceilings?
You can't have one 15inch woofer filling a room that's 25 feet by 30 feet with first octave bass. That's just too much air and not enough cone. I have a room that's 25 feet by 25 feet with 13 foot ceilings and I plan to use 8 of the same drivers as you. I'll be using an Infinite Baffle with 2000 cubic feet of enclosure space. The idea is to not overdrive the woofer and yet achieve bass at 17hz.
Something to think about.
John Inlow
Old 15th May 2006, 03:14 AM   #6
jonz is offline jonz  Canada
Thats 750 sq.ft.... you need two of those...
I got 300 sq.ft..and I have set up 2 sealed 5.5 cu.ft. Temptests..powered by a 1500 watt stereo amp...
Altough I m quiet surprised it's bottoming out that easy...have you visually checked all moving parts on it..spider..coil leads...cone..ect..to see if al is well? Do you suspect a flaw in it..?
Old 15th May 2006, 04:11 AM   #7
mpmarino's Avatar
I have no experience with this driver but could it be underdamped in such a large enclosure? at this page it is recommended for a 2.1ft3 enclosure for a Qtc of .707. It would seem to me that your 'Q' is much lower. Wouldn't power handling go out the window??
Crazy Yankee.
Old 15th May 2006, 08:13 AM   #8
carpenter's Avatar
Default power handling
If one uses a large enclosure, then the driver is going to handle less power before achieving Xmax. This is why it's important to have plenty of drivers in your system. The upside is the lower frequency bass, eq'd of course.
John
Old 15th May 2006, 08:27 AM   #9
carpenter's Avatar
John
Old 16th May 2006, 12:48 AM   #10
hi guys thanks for the responses.heres a pic.you see the adire ada 1200 separate. if i put everyting in the same box-way too heavy. i do realize my room is large for 1 15" woofer. 25'x30'x14' high ceilings.modeled in bbpro i get a f3 of 17hz.thats with a bass boost of 6db per octive at 45hz.i had the ada1200 set at 12db boost,2.5 octive bandwith set to about 40 hz.
i don't know how to calculate my f3 at those settings,can anybody tell me?? but i suspect i was running this sub very low,considering the size of the box.i inspected the woofer and spider-everything seams to be find.i will install .5-1 cubic foot of sand to make the box smaller
HELP- Titanic MKIII 12"+Plate Dayton 500W lascur Subwoofers 8 2nd December 2008 03:53 PM
Dayton Titanic MkIII 10" woofer -- problems Sarchi Subwoofers 9 23rd July 2006 09:03 PM
Dayton Titanic MkIII 15" woofer -- problems chainenoble Subwoofers 4 22nd April 2006 02:39 AM
Dayton 10" Titanic mkIII vs RSHi-Fi vs RSH-O bkoerper Subwoofers 4 26th November 2005 05:57 AM
My first DIY project. The 15" Dayton Titanic MKIII. Pics perpetual Subwoofers 11 18th April 2005 03:56 AM
Page generated in 0.10187 seconds (80.91% PHP - 19.09% MySQL) with 11 queries
