#161 |
Interesting, I just assumed it was the same as the Contrabass.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#162 |
"does the motor rotate continuously in only one direction, "
How could that possibly work?
Candidates for the Darwin Award should not read this author. |
#163 |
So maybe the motor shaft turns back and forth. anyway, thanks again for the pictures djk.
#164 |
The audio signal is fed directly to the servo motor,which turns back and forth depending on polarity,driving the cones via the belts.
Page 2 of this link shows a diagram of how it works. http://www.servodrive.com/Download_f...ContraBass.pdf |
#165 |
"Interesting, I just assumed it was the same as the Contrabass."
It is, just the nomenclature is different. In the blurb on the Contrabass since it is a vented direct radiator system the vent substitutes are 18" passive radiators and the 15" passive radiators driven by the S shaped belt are called 'the active radiators'.
#166 |
Hmm, I guess I can't 'see the forest for the trees' because I'm looking at an assembled CB belt drive system and I wouldn't describe the belt drive as 'S' shaped or the stabilizer belt system as idler pulleys.
Oh well, it's academic since Don's posted something with a drawing of it. Thanks for clarifying the BT7 uses the same system if not the same parts. GM
#167 |
any additional info with the BT7? How about the internal and external dimensions of the box? Does anyone have this info?
#168 |
Look at the Lab 12 sub, very close to what you want, and something you can actually build.
#169 |
...from the patent (page 25)
It is tri-fold -- appox 205" The driver "taps in" at the beginning of the horn (0% offset) The driver "taps out" 20% from the undersized mouth |
#170 | |
Can you send the Link of this patent page... |
| Page generated in 0.08876 seconds (80.41% PHP - 19.59% MySQL) with 11 queries |
