It seems that my dreaded JPL PB12 subwoofer is damaged since it only works when I push the speaker in. I need to find a replacement speaker but I don't know where to find them. The only marking on the back is WFR-12GG01. T found the specs here on Google and that's all I could find: Is it the sub or the crossover?
If somebody knows where I can find a suitable replacement it would be greatly appreciated. |
#2 |
I think this would work if your amplifier is 4 ohms capable.
http://www.ascendantaudio.com/assassin12specs.html http://www.partsexpress.com/pe/showd...number=295-490 If it's a 8 ohms capable amplifier, this is similar to your current driver: http://www.partsexpress.com/pe/showd...number=295-120
DIYaudio for President ! |
#3 |
Thanks for the info Simon5 but I rather not just throw in any OEM subwoofer in there. Using the wrong replacement could burn out the PB12 amp in no time. Anyone who has the JBL PB12 will know how crappy these amplifiers are. So again if anyone knows where I can find an exact replacement (same specs) please reply.
#4 |
Like I said, you think your amp could blow easily so this is the driver you could use and why :
http://www.partsexpress.com/pe/showd...number=295-120 DAYTON ST305-8 12" SERIES II Re 5.7 ohms <-- higher Re so easier load for the amplifier Fs 27 Hz <-- quite similar Le 2.3 mH <-- lower Le so easier load for the amplifier Qms 11.72 <-- quite similar Qes 0.35 <-- quite similar Qts 0.34 <-- quite similar Vas 161.4 liters <-- quite similar Xmax 8 mm <-- two times better SPL 92 dB <-- higher SPL with the same power imput so easier load for the amplifier to reach the same loudness Sd 0.052 m^2 <-- quite similar Bl 16.49 Tm <-- quite similar Mms 90.76 g <-- quite similar Cms 0.35 mm/N <-- quite similar JBL PB12 Re(ohms) 5.30 Fs(hz) 24.80 Le(mh) 3.44 Qm 8.14 Qe 0.331 QT 0.318 Vas(L) 164.30 Xmax(mm) 4.20 SPL(db) 91.00 BL(Tm) 15.18 Mms(g) 97.81 Cms(mm/n) 0.418 Sd(m^2) 0.053 Convinced? Maybe there's better matches. Good luck!!!
#5 | |
If you have one of the older versions that has yet to die, I would say that this is a good excuse to get rid of it, or modify it to work with a different amp. On the other hand, if you have one of the newer amp design models, I wouldn't hesitate to throw in a new driver, Dayton or otherwise, to get it working. Just my 2¢. Just FYI, if you don't already know or haven't already determined, the way to easily determine the type of the amp externally is barcode placement. The non-repairable types will have the barcode at the bottom of the amp, while the 'good' amps will have the barcode near the top, by the controls. Additionally, you could order the original woofer from JBL here for $90 if your deadset on it, but the Dayton, as suggested, is a better option. |
#7 |
I have one in my hands. It came from a JBL sub that the Amp failed. R U still looking?
#8 |
lol 4 years later
a man once told me... |
| JBL PB12 replacement amp | Tee-Bruce | Subwoofers | 1 | 18th June 2007 01:59 AM |
| What to do with a fried JBL PB12 | tarpon | Subwoofers | 8 | 27th December 2006 10:36 AM |
| JBL PB12 dead? | turkish621 | Subwoofers | 10 | 28th May 2005 01:11 AM |
| rtr speaker replacement | kspeng | Multi-Way | 0 | 24th May 2003 01:44 AM |
| JBL PB12 Amp Failure | Galen | Multi-Way | 3 | 28th November 2001 08:01 PM |
| Page generated in 0.09688 seconds (80.43% PHP - 19.57% MySQL) with 10 queries |
