Need help designing a horn
Old 1st May 2006, 10:50 PM   #1
Nichol1997 is offline Nichol1997  United States
Default Need help designing a horn
I have a pair of JBL 10" GT1000 woofers that I would like to design a horn for. The horns would be used for music only so sound quality is important. I have a normal sized room and would like extension down in the 30's Hertz region. Would these be good woofers to do it?
Xmax 7.15 mm
Re 3.23 ohms
Le 2.13 mH
Sd 355 cm squared
Bl 11.48 TM
Vas 61.73 liters
Fs 28.64 Hertz
Qts 0.38
Qms 10.20
Qes 0.40
Pe 260 Wrms
SPL 94 dB
Z 4 ohm
I have built several boxes before, both sealed and bass reflex.
Old 2nd May 2006, 07:24 PM   #2
e-side is offline e-side  Netherlands
Default Re: Need help designing a horn
The horns will be vert large when you want them to go that low. Corner placement will be necessary to get reasonable enclosure dimensions.
Anyway, your woofers could go that low when horn-loaded. I quickly simulated a possible alignment (see attachment). I reduced the mouth area somewhat to keep the size down.
Old 2nd May 2006, 07:28 PM   #3
Resulting frequency response:
Old 3rd May 2006, 12:52 AM   #4
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Maybe you can use this as inspiration....mind you, things can change a lot when drawing in real size on cardboard
Old 3rd May 2006, 02:10 AM   #5
Wow, I did'nt realize it would have to be so big. Thank you for simulating it. Does HornResp also do folded horn designs? I think this might be a better option for me.
Old 3rd May 2006, 09:08 AM   #6
If the horn's still too large, you could reduce the mouth area some more. However, if you want 'flat' frequency response you should increase the horn's cutoff (higher F3), because a horn reproducing the 30 Hz region simply needs to be very large.
You could take the calculated values for throat area (St or S1), compression chamber volume (Vb or VRC), the length of the horn etc. as a starting point. Then you could design a folding pattern to fit the horn into a cabinet. It's important to maintain the horn's expansion through the bends.
Old 3rd May 2006, 09:55 AM   #7
Hi Eside,
you chose a 3:1 ratio for Sd:St. Why?
It seemed to result in very low ripple in the passband. Can I assume that is not coincidence?
For 30Hz you have chosen quite a short horn at 2.72m, resulting in -12db @30Hz. Is the bass roll more due to horn length or Vtc?
What is ATC?
Nichol,
just to give you a feel for some numbers expect a speaker volume of at least half a Labhorn (350litres) for mediocre performance and equal to Labhorn (700litres) for adequate performance, for good performance you may need Tannoy Westminster volume (1000litres). Corner loading can and should be used to reduce the Tannoy target. Corner loading will be mandatory for the 350L cabinet and advised for the 700L cabinet. The Labhorn needs 12cabinets in free space, 6cabinets in single boundary space and 3cabinets in 2 boundary space (floor and wall loading). 1.5cabinets are needed for corner loading but a mouth extender will reduce this requirement to 1cabinet.
Corner loading simulates a mouth area equal to 8times the actual mouth area and can approach 16times when the corner is used to continue the expansion of the actual horn flare.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 3rd May 2006, 10:01 AM   #8
hm is offline hm  Europe
hm's Avatar
Default 10" Basshorn
what you think about that:
http://www.hm-moreart.de/5.htm
Old 3rd May 2006, 10:08 AM   #9
just to confirm some numbers that horn in post8 is 330litres and the mouth area of 0.16sqm cannot possibly do justice to 30Hz music signals. The floor loading from a back loaded horn can only simulate an effective mouth area of 0.32sqm, that's what I mean by mediocre.
regards Andrew T.
Old 3rd May 2006, 10:15 AM   #10
a thought just occured, below the horn loading passband the speaker sees a loading of just the rear chamber and starts to perform as a sealed box design at these low frequencies.
If your system could overload the driver in this situation of high drive voltage at below passband frequency then you need to add a high pass filter to protect the driver.
But you may be able to adjust the rear chamber resistance to give the protection you need but at the expense of raising the low frequency cut off frequency.
regards Andrew T.
Need help designing a hornHide this!Advertise here!
Here's a spiral bass horn I'm designing carpenter Subwoofers 31 24th December 2014 06:36 AM
need help designing 15" folded horn. duck1 Subwoofers 14 8th May 2008 09:21 PM
looking for help designing a horn robotnation Subwoofers 3 13th April 2008 03:00 PM
Designing a horn like a two way speaker ... Onur Full Range 0 21st September 2006 06:16 PM
Horn designing software Puggie Subwoofers 28 21st April 2005 02:25 AM
Copyright ©1999-2017 diyAudio
