Sensurround horns - any information please?
Old 8th September 2007, 02:16 AM   #21
Ian Millar is offline Ian Millar  Australia
This photograph shows one of the 189E drivers in its small sealed enclosure (32mm MDF):
Old 8th September 2007, 02:28 AM   #22
my sealed enclosure of 1 cubic foot (for an 18 inch deiver!)
Old 8th September 2007, 02:31 AM   #23
Horn cabs under construction:
Old 8th September 2007, 02:33 AM   #24
and finished...
Old 14th November 2007, 09:52 PM   #25
spekrhutt is offline spekrhutt  Canada
Hi everyone, I am trying to find plans to build a set of cerwin vega senoir earthquakes. I presently own 8 b36a and 2 b48. If anyone knows where i can acquire some of these plans please let me know.
Old 9th November 2011, 11:45 PM   #26
Mensadan is offline Mensadan  United States
Sorry to dig up an old thread, but I have a few of the 2nd design genuine Universal Studios Sensurround Earthquakes for sale. I bought them thru Clark Stewart back ~1986, when he was the property manager of Universal.
They measure 48" X 48" X 20", and have a single 18" driver. I also have a set of the mouth extenders, so I have the dimensions of them.
These were used in a movie theater in Tuscon, AZ. It was a medium-size theater, so they used 8 subs. I had to buy all 8--still have 4 left. I also had to buy 2 of the huge original ones that used 2 ea. 18" drivers, but I sold them years ago.
Please see my ad in the For Sale section. The subs are located just west of Phoenix, AZ.
Old 4th May 2013, 09:11 AM   #27
Doggyboy is offline Doggyboy  United States
I'm also sorry for severe necromancy but figured why start a new topic when an old one is just as good. >_> I actually have a specific interest in Sensurround though as recreating comparable levels at home was one of the design goals of my eventual IB/floorhorn system.
Two things I was curious about, any suggestions for the modeling of the physics of "horn extensions" whether the ones used for the Sensurround horns or other horns? For instance, until I build up the IB system I expect to use smaller horn subs. (not quite Sensurround but to be honest, this is the only place I so far have ever heard of "horn extensions" even being discussed) If I build extensions to put onto existing horn subs, would it improve low end frequency response, or sensitivity, or does that depend entirely upon the design of the hornsub? (ie does it have to be designed originally to expect/need the extensions, perhaps the Sensurround horns specifically require them)
The other question, and the reason for posting on this forum... can anyone specifically familiar with the original movie Earthquake, or the Sensurround Model _1_ box PM me? My only current information is here Sensurround - Wikipedia, the free encyclopedia :
Surviving equipment
The last two known original "Sensurround Model-1" control boxes are owned by Dolby Laboratories. They are loaned on occasion for revival screenings of films using the process. At least one replica system exists, as it was custom built for a 2004 London revival screening of Earthquake. Sensurround Mod-II and Mod-III boxes are extremely common and relatively easy to find from old theater equipment dealers and can be bought for $50 or so. The Mod-II and Mod-III boxes were mostly just modifications of the original control boxes, but the changes are not easily undone to make them capable of running "Earthquake" because MCA did all the modifications themselves and never released any documentation about the changes made to each circuit card in the unit.
I would like to possibly get in touch with whomever built the replica for the 2004 London revival, or some fan-group that might know about it, or whether anyone has ever reverse engineered or has schematics of the original box with the intent to possibly back-convert a Mod 2/3 box to original "Earthquake" configuration. (OR the possibility of coming up with say a software simulation of the same process - which shouldn't be hard, "random" isn't too big of a deal, right? It just would be nice to maybe try to fine tune the process.)
This actually relates to my desire to create a Fan Restoration featuring proper generation of the bass signals into the LFE channel (and removal of the control tones which were AFAIK not meant to be played?) so that anyone (who bought the movie of course) can get the fanedit and burn a Bluray with "proper" Earthquake sound. Since the Mod 2/3 boxes are commonly available, buying one used and using that to record the bass for the other Sensurround titles and remaster the audio can use real hardware, the trickiest feature is... the original Earthquake.
(now maybe people are starting to see why i'm needing 120db at 16hz since thats what Sensurround specced at in the theater. ; ) Wait til you see what future projects I have in store if I get that 4hz response...)
Old 4th May 2013, 09:35 AM   #28
Brett is offline Brett
Brett's Avatar
According to Wiki, it's a pseudo random noise generator with a 17-120Hz BW. Not difficult to design something to do similar. If the idea is to generate an effect to match the original and put that onto a bluray, you don't need hardware at all. Are you sure the efect hasn't been added to the commercial DVD releases of the movie? It would be a doddle to do for them. Easy enough to measure with spectralab or similar.
And the 120dB at 16Hz is not uncommon in certain HT circles and not difficult to obtain, especially compared to 40 years ago. Check out the DIY section at AVS
Old 12th May 2013, 05:57 AM   #29
Doggyboy,
Can't help with the electronics, but the reason for the mouth extensions was to continue the horn flare in order to get down to ~16Hz. Small movie theaters used 4 subs, medium size used 8, and big theaters used 16.
Most of the rear subs fired into the rear corners, so used the walls to continue the flare. But they couldn't use the front corners because that's where the front fire escape doors were. So, they simply laid the front subs in a line across the front and used the mouth extensions for the flare.
I have one set of the originals. They're made from 3/4" plywood. I'll measure them tomorrow. Check these photos.
Amazing what my wife puts up with. It helps if you feed them ice cream.
Now I just fire it into a corner.
Old 12th May 2013, 10:17 AM   #30
JLH is offline JLH  United States
JLH's Avatar
The Epicenter Bass Restoration Processor
If you are looking for electronics to enhance the low frequencies, then you might want to look at the Audio Control Epicenter signal processor. This was a popular piece in the car audio scene. The way I understand it, it samples the bass frequency content of the incoming signal and then synthesizes an additive signal that is an octave lower. So if you have some 35Hz bass coming through, it will add in some 17.5Hz information and sum it with the original signal. It is a 12VDC device, so you’ll need a 12VDC wall transformer to run it. You can also read the patent on it, it is patent number 4698842.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Sensurround horns - any information please?Hide this!Advertise here!
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
need information on these horns... discomonkey Full Range 1 13th June 2009 12:14 AM
W-422 Information danloani Full Range 0 28th May 2007 03:14 PM
looking for information about Sub Horns cody6766 Subwoofers 17 3rd February 2005 11:45 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
Copyright ©1999-2017 diyAudio
