Hi all.
Firstly my apologies for a lengthy post, but I'd like to explain where I'm going.... Basically, I wish to build a replica of one of the original horns as used in the Sensurround project - a horn capable of reproducing random noise centred around 15Hz at a high SPL. So what was Sensurround? For those of you who don't know, Sensurround was an audio enhancement to a few films released during the 70s, the idea being to create a subsonic rumble - typically around 15Hz - to heighten realism during action scenes in films such as 'Earthquake' by creating vibrations within the human body, but very little audible sound. I understand it was normal for 6 horns to be positioned around the auditorium - 1 in each corner, utilising the walls as an extension to the horn, and another two stand-alone units behind or to the sides of the screen. Cerwin-Vega were the company who designed the drivers and cabinets, but no longer have any information. These horns were large, as you'd expect, and from what limited information I have were designated the 'W', 'C' and 'E' horns. It is the 'E' horn I wish to build as it appears to consist of 2 separate, and slightly smaller components. Now why: I am known locally as the 'guy who likes speakers', and this is why I was approached by a small local theatrical charity who have asked me for advice on constructing a device for creating subsonic rumble, as they wish to use Sensurround type effects during some of their presentations. The person concerned did go to see Earthquake in the 70s, as I did, and we both agreed this is the effect needed. Incidentally, normal subs don't do the job - we tried! It was also agreed that a close copy of one of the original units, both in construction and finish would be a good nostalgia trip for some, and this is what I ultimately wish to build. Although the finished unit has to be portable to a degree, size isn't too much of an issue as it would remain in situ for weeks at a time and only be moved occasionally. Corner placement would be ideal. Do any of you have copies of the original plans for these horns, including dimensions? How would modern 18" drivers serve in these horns? (I have a pair of Fane Colossus 18B 600s available for this) How about photos so I can see what they actually looked like? Anyone in possession of one of these beasts? They had to end up somewhere, after all! Many thanks for any help you can offer. Andy. |
#2 |
Do a search on this forum for Magnetar.
He has three on his back wall. His fire downard and couple with the floor. Here is a link that he posted... http://www.in70mm.com/newsletter/200...ges/horn_1.jpg Hope this helps... |
#3 |
Thanks for the reply and the link. I already have a copy of the diagrams, but will attempt to get in touch with the member you suggested.
Andy. |
#4 |
Magnetar posted this picture of his three (model m) Sensurrounds
http://hometown.aol.com/batespm/images/bass.jpg |
#5 |
That's interesting.
They don't appear to be quite as the diagrams would suggest - I must assume this is a type not illustrated, which the 'M' type you gave them would suggest. I'm wondering for the moment if they are original Sensurround units, or similar devices that Magnetar has built, and called 'sensuround' after the cinema models. I've sent Magnetar a private message anyhow, outlining my query much as I've desctibed it in this thread, so hopefully he will enlighten us. Those horns certainly look the business, whatever they are! Andy. |
#6 |
Magnetar is a quiet, gentle soul -- never one to speak his mind
He has one of the finest horn rigs I have ever seen (and home-built). Also, he loves HEIL AMTs (as I do). Here is another of his posts -- an interior shot of one of his Sensurround Ms (beefed and modded for his 18" driver) http://hometown.aol.com/batespm/images/admhrn.jpg It bears a remarkable resemblance to the M-Type in the diagrams he posted (bottom-most right diagram) Best Regards |
#7 |
If it is not music but some rumble you might as well use some sort of resonator like a purpose-built TML.
Regards Charles |
#8 |
I think I have my model numbers a bit mixed up - the model I'm interested in is the 'M' type, as you say it appears lower right on the diagram. Quite where I got 'E' type from, I'm not sure....
And yes, Magnetar's M horn is obviously based on the Sensurround original, or is an original he's modified, and it's this I wish to construct. Two of them. As wood is reasonably cheap, and my free time is... um.... free, I'm going to build a pair for working into the corner of a large room, as intended for the originals. It's an unexplainable urge - I'm sure you guys can appreciate that! Just need to study horn theory a bit more to make sure I'm not making any huge mistakes with the dimensions, and don't destroy expensive speakers through over-excursion. Charles, thanks for your comment - what you suggest might do the trick but I feel I've gone too far down the horn route already - I'm developing a bit of a passion, you see...... Meanwhile, any more photos or specifications/dimensions of the original Sensurround horns will be very welcome, especially information on the original drivers used, and how they differed from what is available now. Andy. |
#9 |
Hi all. An Aussie Sensurround freak here
Cheers, Ian |
#10 |
Please excuse a few "typos". I use a voice recognition program which thought "dual integrator circuit" was "dual integrated circuit" and that "point" was a full-stop etc... stupid thing!
Ian
| need information on these horns... | discomonkey | Full Range | 1 | 13th June 2009 12:14 AM |
| W-422 Information | danloani | Full Range | 0 | 28th May 2007 03:14 PM |
| smith horns and using compression horns for a Karlson party speaker project | bikehorn | Multi-Way | 10 | 27th December 2005 09:10 AM |
| looking for information about Sub Horns | cody6766 | Subwoofers | 17 | 3rd February 2005 11:45 PM |
| Horns: Vibrations and resonances in metal horns | Rocky | Multi-Way | 10 | 28th July 2004 01:38 AM |
| Page generated in 0.13305 seconds (83.68% PHP - 16.32% MySQL) with 11 queries |
