Old 30th April 2006, 06:08 AM   #1
zuki is offline zuki  United States
Default how big of a sealed box will this woofer need ?
specs .
fs 20hz
qts .8520
qes 1.0464
qms 4.5875
vas 227 L
sd .0676
re 3.2 ohms
thank you
Old 30th April 2006, 06:24 AM   #2
ostie01 is offline ostie01  Canada
What brand is this speaker, maybe it is the bass box pro modeler
Old 30th April 2006, 07:21 AM   #3
it is a phoenix digital square woofer
Old 30th April 2006, 11:34 AM   #4
lndm is offline lndm  Australia
This woofer will have a hump in its response unless you put it in a very large box (at least Vas in size). It is my opinion that it may have been designed for parcel shelf use directly into the car's boot.
Old 2nd May 2006, 05:16 AM   #5
it says the ported box recommendation is smaller than the sealed box recommended.
sealed 68 l
ported 47.6 l
with 100mm inside port diameter
and 215 mm long.
Old 2nd May 2006, 05:43 AM   #6
Here is what your response may look like. The pink trace is for the 68 litre sealed box, then blue trace is for the vented box.
Old 2nd May 2006, 05:59 AM   #7
i figured the ported box would be larger.
not a very good woofer is it.
i have 4 of them from a couple of years ago.
Old 2nd May 2006, 06:16 AM   #8
These are car woofers aren't they? If they are going into a car, the bass needs will be different and they will probably be good.
Woofer choice in 2-way sealed cabinet tinos5601 Multi-Way 1 13th March 2007 04:55 AM
Paulspencer: AV12 woofer, PR or sealed? BAM Subwoofers 1 25th March 2005 05:56 AM
Vifa P21WO-39-08 Woofer - Sealed sunil Multi-Way 62 25th September 2003 02:57 PM
38 cm. woofer in a sealed box, any experience? giolight Multi-Way 6 9th December 2002 11:35 PM
sealed woofer box giolight Multi-Way 0 2nd April 2002 09:06 PM
Page generated in 0.08365 seconds (77.85% PHP - 22.15% MySQL) with 11 queries
