Old 30th April 2006, 05:20 AM   #1
ostie01 is offline ostie01  Canada
Default Want to kow the tuning freq of a vented box.
HI, would like to know how can I measure the tuning frequency of a particular bass reflex box that is already built. which testing should I do. I have a woofer tester II from Dayton but not sure how to use it and how to read the result I'm going to get.Should I put the woofer in a seal box first to get some measurments and compare them with the woofer in my real design.I know how to get parameters from a raw driver with my woofer tester but not sure how to do this with the final design. I also have the harris tech bass box pro 6 but again, not sure how to use it when the box is done.My woofer is an Eminence Omega pro 15 in. 800watts in a 5.5 cubic feet with a 2 X 15 vent approx 6 in long. Fs is 39 Hz. What could be the best tuning frequency for this woofer, below or above 39 Hz. As always many thanks
Old 30th April 2006, 09:03 AM   #2
simon5 is offline simon5  Canada
To know what's the tuning frequency, just measure the impedance. You'll reach an impedance low at the tuning frequency.
DIYaudio for President !
Old 30th April 2006, 10:29 AM   #3
Send a message via MSN to noodle_snacks
http://www.bcae1.com/spboxad3.htm
outlines how to measure impedance, low voltage = high impedance. you need to find the low point of the impedance between two peaks either side of the vent tuning frequency. Follow the method on that page to do so. Attached is a picture of the point you actually want to find.
Tuning Freq below Fs of driver in a Vented Box? mymindinside Multi-Way 2 7th August 2007 04:53 PM
PR tuned to different freq mashaffer Multi-Way 4 3rd August 2007 01:10 AM
Vented box tuning frequency manek Multi-Way 6 19th October 2004 04:50 AM
Ideal cone excursion at box tuning freq. Circlotron Multi-Way 14 23rd September 2003 01:07 PM
Vented box tuning Ilianh Multi-Way 6 16th January 2003 01:42 AM
Page generated in 0.10120 seconds (57.03% PHP - 42.97% MySQL) with 11 queries
