Old 29th April 2006, 01:47 PM   #1
Default One push-pull or 2 sonotube TLs?
I've got a pair of Seas CA21RE 8" woofers and have been playing with Sonotubes...I have them mound push-pull in a 48"x10" tube running passive right now. If I mount them separately will I get enough SPL to keep them passive? Or should I keep this arrangement and get a plate amp? Right now they are sharing my NAD 3020 with Boston A60s.
thanks!
Old 29th April 2006, 11:31 PM   #2
owdi is offline owdi  United States
owdi's Avatar
If you are looking for more output I would try a push push configuration with the drivers facing out on each end of the sonotube. You could stand the sonotube up to reduce the amplitude of room modes.
Dan
Old 29th April 2006, 11:41 PM   #3
Neato! How does that config boost output? I assume if they were wired in phase I would lose the push-pull harmonic cancellation?
Old 30th April 2006, 01:52 AM   #4
ScottG is offline ScottG  United States
Dan
..push-push in that configuration would be a dipole. It would reduce output (spl).
..push-pull in that configuration would increase output above the T-line's output and reduce output starting a bit below the T-line's output.
perspective is everything
Old 30th April 2006, 02:07 AM   #5
Default Re: One push-pull or 2 sonotube TLs?
thanks!
short answer:
mount each in their own tube with correct lengths for the driver's fs (..and dampen the tubes with fiber fill);
if stereo then connect each to their own plate amps, if mono connect the drivers in parallel to a single plate amp;
plate amps are cheap. In particular note this thread:
Buyout Plate Amp
Old 30th April 2006, 02:45 AM   #6
I'd be interested in the long answer too, since I always want to know why something is I had seen a few project sites with push-pull setups they raved about, but Mr. Pass and our own GM recommended dual tubes.
The trick is, it will be a few months before even a $50 plate amp is in my Spouse Acceptance Factor parameters. So I was hoping the dual tubes might be a lot better passive than one push-pull...or at least wondering. I suppose the best approach is to wait, get an amp, and try different tube configs; sounds like it will be impossible to compare passive setups.
For the record, she calls it "El-poop-o."
Old 30th April 2006, 04:25 AM   #7
Well for that then we would need to exactly how the drivers are utilized.
IF its like Pass's first "legend of el pipe-o" then the 2nd order distortion cancelation via push-pull operation is at best minimal. (..the reasons are complex - basically the pipe operates in a not to disimilar fashion to a a push-pull configuration, utilizing both methods at the same time substantially counteracts the effectiveness of the push-pull operation.)
Furthermore the pipe with 2 drivers will not exhibit as strong an spl in the pipe's range of operation when compared two pipes (which effectivly double spl, almost +3db, at these lower freq.s).
And sure, you can use two pipes with drivers connected together in parallel and hooked up to your current amp - essentially the same as you currently have. With this you should be able to increase the spl of lower freq. response by almost +3db as mentioned above. There are of course several reasons to buy a plate amp, but if you can't "swing" the purchase right now thats OK - it will still be worthwhile going the two pipe route.
Old 30th April 2006, 12:21 PM   #8
Wow, interesting. Seems like I saw a lot of tube projects with push-pull drivers, though? like this: http://www.teresaudio.com/haven/subs/subs.html
what do you mean by how they are utilized? right now they are mounted clamshell, out of phase, with the in-phase woofer downfiring. Sag is about 4.8%.
I thought the whole point was to guide the back wave, but Pass has his second version firing up. Sure would be easier for mounting since that way you don't need a box on the bottom. at the end he says:
"If you have an 8 foot ceiling, you can make two out of a 12 foot piece of 8 inch diameter, and find yourself decent 8 inch woofers resonant at about 40 Hz."
These drivers' relevant specs are:
Qts: .48
Vas: 81.3l or 2.871cu.ft.
Fs: 31Hz
Quarter-wavelength at Fs is 9 feet or so, I suppose I could fold an 8 inside a 10 (tubes). But it seems like with room gain a lot of folks prefer to tune for a bit above that. I estimate about 50-60Hz with a 48" tube stuffed...
Old 30th April 2006, 10:59 PM   #9
Qts: .48
Fs: 31Hz
"How they are utilized".. by that I mean do both drivers:
1. exit in-phase to the room?..and,
2. exit reverse-phase to the pipe?
Pass's second version is better with respect to distortion and T-line operation. (i.e. place the driver on the end like Pass has in the second version.) Note that you can further dampen the driver's resonance and its fs with a HIGHLY stuffed pipe. (i.e. less distortion and a more extended response.) The downside is that you will loose some efficiency and should utilize a slightly longer pipe. Furthermore the sub becomes less suitable for extended operation at higher freq.s.
Do NOT shorten the length of the pipe.. consider horizontal placement in-room instead (i.e. "running" along the bottom edge of the room). Conversly, consider a folded or spiral line.
Old 30th April 2006, 11:47 PM   #10
[B]
Not exactly sure. One is mounted in the pipe, down-firing, in phase with the mains. The other is mounted in front of it (under), reverse-phase.
It sounds like as long as I'm going to be passive for a bit it's worth a try. Should I do 2 8" tbes or 2 10" tubes?
I could buy a third tube of either size, cut it in half, attach the halves to the originals (good place for some kind of stuffing-stopper) and have 2 72" tubes. with 8" tubes this gives me a Vb of 2.094cu.ft, still a little under Vas.
PUSH-PULL SONOTUBE vs. TWO SONOTUBES? elves1111 Subwoofers 7 5th November 2008 08:10 PM
6T9 push pull Jaime Tubes / Valves 2 26th December 2007 04:14 PM
An all DHT push pull amp. Eusebius Tubes / Valves 3 28th October 2006 12:37 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.15595 seconds (82.81% PHP - 17.19% MySQL) with 10 queries
