recomend an 8" sub for me
space is verry minimal and would like to get the absolute most from this sub and 8" is the biggest i can use so no 10s or 12s
i want high power handling and extremely high x max i have found the parts express tang band woofers with 12 mm x max
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-833
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=264-854
does anybody know af anything more or better than these ?
i am into car audio and even though they are bigger and usually have a higher x max i cant sem to find a decent car audio woofer to fit my needs most companies make 10-18"subs
any links or help would be great thanks
The MCM is a clone of the Tang Band, and is capable of greater excursion. However, some report that it's suspension weakens over time. MCM's specs are off, too. Search the archives if you are interested. It's similar to the Tang Band but with a higher VAS.
I've used the MCM in a T-Line and a 1 cu ft passive radiator system. It's great for the money either way. Due to the lower VAS, the Tang Band will work in a smaller vented box. If you've got the extra $15, the TB is probably worth it.
