Old 26th April 2006, 04:11 PM   #1
Default Sub burnt bad. Garbage?
Hey guys, I hang out at the projection area, but here is my deal. I had a fusion 1404 amp sitting around, so i hooked it up. Then I had a pyle 300w sub that I had in the house for a while. Decided to play around, even knowing I would be overdriving it. Well, long story short, it lasted about 10 minutes. So, I replace the sub now with a good one. But question I have. Do I throw away the old burnt sub, or should I do something with it, like rebuild it? I don't know much about them, so if I can rebuild it, that would be ok. Thanks Chad
Old 26th April 2006, 04:33 PM   #2
tade is offline tade  United States
Send a message via AIM to tade
I would say keep the magnet assembly for later experimenting and ditch the rest. I am a fatalist though.
Old 27th April 2006, 04:22 AM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Keep the old driver as it might be OK for a passive radiator.
No longer DIY active
Old 27th April 2006, 11:43 AM   #4
oh, great idea. If you can cut off the magnet or at least get to the voice coil to cut it off or unstick it.
Old 27th April 2006, 01:59 PM   #5
Thanks everyone. I think using it as a passive is a great idea. Thanks.
is this garbage? rtill Solid State 4 10th November 2007 02:00 AM
Cdt Es 620 Comps= Garbage SIDEWALKSISSY Car Audio 3 27th May 2006 07:30 PM
Electronics workbench = garbage sndscietist The Lounge 1 3rd July 2005 07:56 PM
Garbage audio CD's Rimband Everything Else 5 10th July 2004 06:32 AM
Page generated in 0.07759 seconds (75.45% PHP - 24.55% MySQL) with 10 queries
