Gee, my title kind of sounds like a pickup line for an online personals ad...
Anyway, I am very frustrated. At present, I am running a Blueprint 1503 in about 7 cubic feet, tuned to around 18Hz. At first, I complained that it wasn't musical enough (which, at the time, was true). I managed to cram a little damping material in there, which helped a little. Now that I've changed receivers to one that has a much more complex bass-management system, it sounds much, much better. So if it is absolutely great for home theater, and is much better for music, what is my complaint? The size of the beast. It is a sono-sub, so the tube itself is 16" in diameter, but the base is 18" in diameter. And, the thing is abut 6-feet tall. Very unsightly, to boot. I want something smaller, but I have particular demands... These are: *I don't want to lose very much of my HT performance *I want an extremely musical, non-boomy sub for music *I want a box, not a tube *The box cannot exceed 24" cubed (the smaller, the better, really) *Must have high-power handling and boast an impressive SPL, in case I need to show off at any time As far as HT goes... The current alignment hit -3dB pretty high, but stays -3dB all the way down to 17Hz or so. So, in a sense, it is a flat frequency response. But, group delay is enormous. I think it hits something on the order of 60ms at 20Hz. And, like I mentioned before, the size is killer. I need something more pretty to look at. As far as music goes... I have had my eye on servo subs for some time now. I am lusting after a Velodyne HGS/DD or Paradigm Servo-15, but they are simply WAY out of budget. I cannot afford $2000-$3000 for a sub (for anything, really). I definitely want servo performance for music. I need smooth, blending bass because I mainly listen to classical music at lower levels. However, if I do switch to rock music, I also need powerful, well-articulated slam for kick-drums. As I mentioned before, I have the Blueprint 1503 already. It seems to be a solid driver, but I've heard that these things have enormous inductance, which could be a key to my problems. I am not keen on using a parametric EQ because I don't have the time or patience to get everything flat. Plus, I really want to rid myself of that unsightly tube. For budget, I could go as high as $1000, but would prefer to do much, much, much less. As cheap as possible, really. To sum up: *Low distortion, servo-like performance for music (smooth for classical, yet powerful for rock) *Maintain powerful slam and dig deep for HT *Smaller box (preferably sealed) *As cheap as possible I wish I knew the exact Le of the Blueprint, it would help out in simulations. Anyway, what I am asking will most likely need a very high Xmax driver, or several slightly smaller drivers. Yes? I am thinking something on par with a Sunfire... Does anyone have any ideas on how I could go about getting something like this working? Hopefully this will spark some creative thinking that will yield a creative answer... Thanks all |
#2 |
I just finished a pair of the Peerless XLS 10" with the passive radiator in a little over a cubic foot box. I can't believe how accurate they sound. i would really recommend that you get two smaller subs like this. Less stress on each individual sub, smaller enclosures, and if you place them right you get the amazing benefits that a pair of subs have when it comes to eliminating standing waves. Almost no dead spots in the room.
#4 |
I'm not sure if it will go quite as low as you want, buy I love my Dayton RSHF 12" sub. The sound quality is really nice regardless of the price IMHO, though the cost is quite reasonable too. My hearing cuts out at ~23Hz, but the sub hits hard down to that and below (I can see the cone going nuts, but can't hear anything), but I haven't measured to get great numbers, but qualitatively I am really happy with it so far. If you throw a couple of those together with the amp of your choice, you should be able to get some serious output without sacrificing too much space or sound quality.
I am sure there are better options out there, but I am really happy with mine! |
#5 | ||
http://www.acoustic-visions.com/~aco...s/stryke_pr18/ or here : http://yellow.mynethost.com/~bv12636...45d378eb4a306d Now at the end you talk about something small with servo performance, then I would suggest purchasing as much Rythmik Audio Servo kits that you can afford... they are 409$ each currently on sale, available here : http://www.rythmikaudio.com/servo_product.htm You will lose this with the servo, well depending how much kits you purchase... Quote:
DIYaudio for President ! |
#6 |
I have been discounting the Peerless for years because they have such a low Xmax, but I suppose they are good sounding drivers (which would account for their popularity). The same thing with the Daytons since they came out. They are good lookking drivers, but I prefer a little more excursion head room...
I've had my eye on the Rythmik kits for some time now, but I am holding out (possibly indefinitely) until he gets a 15" version out there. I am at work right now, so I cannot do any figuring, but I will when I get home. I am going to play with a setup kind of like the Velodyne 1812, except mine will have to be a 1512 (unless I replace the Blueprint). I still have an old DPL12 hanging around, which was a darned good sounding, low-distortion driver, but it did absolutely nothing for HT. Maybe I can get something rigged up... I am also going to see if I can borrow some kind of meter from someone that measures inductance so I can figure out, once and for all, what kind of inductance the 1503 has... Thanks again all... |
#7 | |
Anyway, I really hope you come up with something that works for you! David |
#8 |
You could do a basic Maxwell Bridge to measure the inductance yourself.
I still think your driver with dual 18" PRs would be wonderful.
#9 |
What would be the drawbacks of using one AE PR18-1600 instead of two 2500's? And, what would be the drawbacks of using three PR15-1050's instead of either of those?
I can get three 1050's for only $10 more than one 1600, and $15 less than one 2500. And, I can always add more mass to them to get what I want from them... But, what would I be giving up for this? Thanks... |
#10 |
One AE PR18-1600 will lack excursion if you want to use the full power your driver can take (1000W) at frequencies under ~17 Hz.
The rolloff is less shallow with two PR18s and the PRs never run out of excursion. Dual PRs cancel each other motion so your subwoofer will not walk on the floor. You are right, my solution was a bit overkill. A single AE PR18-1600 will work correctly. Two AE PR15-1050 with 350g added mass on each will work correctly. Three AE PR15-1050 with 750g added mass on each will work perfectly. I'd use dual 15" instead of a single 18" so it doesn't walk on the floor. If you have spare money, dual 18" or triple 15" is nice for bragging rights. You can also achieve a better rolloff IMO, closer to room gain. Also, if you like it loud, it will be less problematic, because you could only blow your woofer, the PRs will survive any abuse. Single 18" and dual 15" are close to their excursion limits. You must tune the PRs lower to switch the excursion limit a bit lower in frequency but you get a faster rolloff. Of course, if you use a rumble filter, it's less problematic hehe!
| Page generated in 0.12730 seconds (79.73% PHP - 20.27% MySQL) with 9 queries |
