Hi, i have recently blown a bass driver for my sub,
Can anyone recomend a very sensitive budget driver? Bass response down to bout 40hz, 500-1000w, 15". So far im looking at the eminence drivers. |
#2 |
What are the enclosure specifications of your sub?
Wkr Johan
Impossibilities we do immediatly, miracles take slightly longer. |
#3 |
200 litres. 18mm mdf
1 x 0.5 x 0.5 Meters Bass reflex tuned to 40hz. (5 ports rear firing) |
#4 |
Are you using it at home or as PA (it seems a bit big for that usage) or any other special SPL requirement? Eminence has some suitable drivers but they will about all introduce a powerdip even in a normal sized enclosure. In 200 ltrs tuned to 40 Hz about every 15" PA speaker will have a powerdip making it easy to keep blowing your speakers. Especially with budget drivers.
Wkr Johan
#5 |
it is for PA. i would like a very high SPL at about 50 - 100Hz (to give that resonance feeling in the chest). My old drivers were absolutly S***. I think they were about 90db/w/m.
Any suggestions? i have about £100 to spend on it but it would be prepared to spend more if a MUCH better driver is at a slight increase in cost. |
#6 |
For PA usage your current box is pretty big, it would actually almost be more suited as a double 15" reflex. Most 15" PA speakers perform best in a 80 - 140 ltr cab.
For kick you can tune a bit higher say 45-50 Hz. Your chest/lungs (if fullgrown) will resonate around 120 Hz, so cross around there or a bit over, it will make the speaker sound louder anyway. From Eminence the Kappa 15LF will show good value for the money. Any series beneath it lacks Xmax (that's bad). It will be around 95 dB/W/m. In your cab as it is 300 Wrms will be about the max. power it can handle. 110 ltr tuned to 47 hz would raise the powerhandling with about 200 watts. In any case it would be a big step up form what you have now. You might be interested in going hornloaded by the way. You could easily raise the sensitivity over 100 dB/W/m Wkr Johan
#7 |
my cab does have twin drivers! but i have blown one of them.
Also could i reduce the volume by putting an object inside the cab? |
#8 |
Yes you can put objects in the cab if they don't vibrate or move (heavy things, better if you glue them). It's a bit of a waste of space, better to get two drivers or build a new cab hehe!
DIYaudio for President ! |
#9 |
The Omega Pro 15" should take some abuse; 4 inch voicecoils. Bigger voice coils dissipate more heat. The Magnums or the Kilomax look nice too. I don't know if any of those are suitable as horn drivers.
Blocks of styrofoam would do to take up volume; you want something stiff but light, unless you don't need to move the cabinet. Check out: http://www.speakerplans.com/index.php?id=home The Kappa 15LF is one of the suggested drivers for this cabinet: http://www.speakerplans.com/index.php?id=hd15horn I'm tempted to build a couple of these since I have the Omega 18's already: http://www.speakerplans.com/index.php?id=186horn |
#10 |
What is the gain in db of a typical horn?
Is there a downside apart from size of building a horn? |
| Biggest connector in the world? | peranders | Parts | 3 | 13th May 2009 04:38 AM |
| another biggest, most, | tomtt | Multi-Way | 3 | 21st October 2008 04:08 AM |
| Biggest Aleph 2's yet? | Mattyo5 | Pass Labs | 32 | 13th April 2005 11:38 AM |
| Biggest amp | skyraider | Chip Amps | 40 | 8th November 2004 06:57 PM |
| who make the biggest plate amp? | slicemaster101 | Multi-Way | 20 | 4th May 2002 12:33 AM |
| Page generated in 0.10675 seconds (79.09% PHP - 20.91% MySQL) with 10 queries |
