Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 19th April 2006, 10:10 AM   #1
Default Subwoofer crossover / subwoofer module design
hey guys,
after doing a lot of internet research about active subwoofer modules like e.g. the mivoc am 80 or detonation dt 50, i decided to have a go on building one on my own.
my setup: my main speakers are cyburgs needles, which some of you might know, with frs8-speakers. some day, i will upgrade them to tangbands, but for now,a subwoofer seems more important to me.
i'm building an 41hz amp3 to power them (maybe i don't f**k up the second one, which i ordered last week)
my plan for the module is to use a buffer opamp, a 4th-order-linkwitz-riley crossover and maybe add a phase shift, quite like in this project at sound.westhost.com
now the questions are:
*do i split up the audio signal before the power amp for the needles and should i use a higpass-lr-crossover for the needles?
*or do i extract the bass signal with a crossover behind the poweramp, as one would usually do with standard subwoofer modules? a problem in this case might be, that the amp3 runs in bridged mode, and therefore none of the outputs is on ground, which might cause a lot of problems.
I'm really looking forward on some input from you guys, and I will do a documentation of my build,as soon as it has left the planning stadium.
all the best,
michi
Old 19th April 2006, 10:43 AM   #2
Khron is offline Khron
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Usually, active filters are placed BEFORE the power amps.
Yes, a high-pass for the needles may very well be justified (we don't want any humps in the frequency response, if possible), because your needles might overlap too much with your sub.
I intend on doing something like that someday (when i'll have the cash to buy a decent sub driver)
Old 19th April 2006, 10:49 AM   #3
Did it Himself
richie00boy's Avatar
I would use a filter before the Needles, but make it more of a 'protective' filter than a crossover filter, i.e. set it to cut in below the bandwidth/resonance of the needles. This way it doesn't take any noticable sound away from the Needles (necessary to get good integration with a mono sub), but it stops them being driven so hard.
And yes, there are capacitors in the circuit. One is even employed to form the dreaded bootstrap on the voltage gain stage. Get over it.
-Burning Amplifier #2, Nelson Pass
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 20th April 2006, 09:49 AM   #4
thanks for the quick replies!
so now my plan is as follows:
+ a buffer opamp on each channel
highpass section:
+ a 24 dB/octave lr-crossover (i'm not sure yet about the crossover frequency, i think 80 Hz should do, as the needles play quite happy down to 50 Hz) on each channel
lowpass section:
+ another buffer to add the two channels
+ a 24 dB/octave lr-crossover with the same crossover frequency
What do you think - should i use output buffers with adjustable gain to match the volumes, or would potentiometers do the job?
i ordered all the parts now, and as soon as I get them, I will start building.
Old 20th April 2006, 11:31 AM   #5
Did it Himself
The level matching can be achieved simply with the power amp volume control.
Thread Tools
subwoofer amp module hpolkerman Subwoofers 10 19th July 2009 08:29 PM
What do you want in a subwoofer module? thadman Subwoofers 2 10th April 2009 06:55 PM
subwoofer module on entertainment center gychang Subwoofers 0 13th August 2008 03:18 AM
KEF Subwoofer TDM-45B Crossover Design misterbobman Subwoofers 2 12th June 2008 03:59 AM
Subwoofer Crossover Dj BASS AMP Solid State 7 30th December 2005 05:46 PM
Page generated in 0.15378690 seconds (81.81% PHP - 18.19% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
