#11 |
If your tweeter is an aluminium or titanium diaphragm, you could be hearing tweeter resonance.
What speakers are you using? Also, the Audigy 2 is also a very poor performer that high in frequency. I don't know if SweepGen output in 44.1 kHz or 48 kHz. 48 kHz causes less problems that high in frequency with an Audigy 2. The Creative X-Fi line corrected the problem with a beefy hardware resampling algorithm. M-Audio Revolution line doesn't have this problem.
DIYaudio for President ! |
#12 |
My tweeters are silk domes, Audio Pro Avantek Six Floorstanders... But Audigy 2 was measured in some beanchmarks nearly flat till 19.5khz...Being -6db in 20khz doesn't mean it can buzz, right? Anyway, I will try different cards and see... |
#13 |
Silk domes are supposed to be very "smooth" that high usually...
Yeah at -6 dB it should be less loud... trying another soundcard is probably the best idea. Try an X-Fi or a M-Audio Revolution... Most soundcards have problems that high, except high-end soundcards.
#14 |
I found what will I do!
I will make a wav file with 20Hz and burn a cd. Then I will play it through Audigy 2/PC and then through my separate sony cs-player, to find out what is going on! Thanks for the help though |
#15 |
Then try the same 20 kHz wav file, but record it at 48 kHz if you can and play it on your Audigy 2.
Audigy 2 is way better at 48 kHz than 44.1 kHz. Good luck!
#16 |
Thanks for the advice!
I also have another question about Fs. Experienced people say that it is the point where driver impendance is maximum I have noticed that its true with most drives, but I found out that it's not the case with this Excel woofer: http://www.seas.no/excel_line/excel/E0017.PDF The impedance peak is at 60hz while the Free air resonance at 31Hz What is wrong? |
#17 |
Did it Himself
From the seas datasheet at top of graph:
The loudspeaker is mounted in a closed box of 12 l net. volume So obviously resonance will be shifted up somewhat.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#18 |
Hm!
![]() Well, Seas seems to be a little different compared to other companies that measure their drivers in free air, isn't it? Does these measurements help a loudspeaker designer? I mean which one is preferable? (cabinet measuring or free air) Regards, Mike |
#19 |
Sorry owdi for not acknowledging your suggestion about WinISD.
It works great also. Thanks! |
#20 | |
They give both, free air and in box measurements. Good stuff.
| choosing specs for driver that will be used for OB | c3conv | Multi-Way | 3 | 21st November 2008 07:28 AM |
| how to understand driver specs? | gasstronamicle | Multi-Way | 4 | 12th November 2007 07:48 AM |
| How can I find a driver's specs | fin1bxn | Multi-Way | 0 | 24th January 2007 01:36 PM |
| Focal driver specs??? | BigSmooth | Multi-Way | 0 | 23rd July 2005 08:26 AM |
| Any specs on this JBL driver? | Bull | Car Audio | 4 | 19th September 2003 08:21 PM |
