Just an idea Just an idea - diyAudio
Just an idea
Just an idea
Old 8th April 2006, 03:30 PM   #1
bob123 is offline bob123  United Kingdom
Lightbulb Just an idea
I was wondering if it would be possible (or has been done) to make a speaker that uses hydrolics to increase the movement of the speaker. Using solenoid to move hydrolic fluid which can be used to increase the speed and movement of a speaker. As shown in the (badly drawn) diagram.
Doing this with a big electromagnet to drive the fluid the surface area of the speaker could be huge. It would only be any good for very low (almost subsonic) frequencys. But could seriouly make some bass.
What do you all think?
Old 8th April 2006, 09:19 PM   #2
dscline is offline dscline  United States
To what end? You are simply trading surface area for excursion. Since displacement is the produce of both, you are gaining nothing. The net result would be that the only difference would be that you'd be adding driven mass and friction, neither of which is a good thing. On top of that, if you believe that doppler distortion is something that can produce noticeable degradation, you are actually better off giving up excursion for greater surface area. The only benefit I see is being able to reduce excursion in the motor, and not having to go to great lengths to provide linear power at such great excursions. But it seems the negatives would far outweigh the positives.
Old 9th April 2006, 09:01 AM   #3
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
Forget the hydralic fluid, you're just wasting energy and limiting frequency. Use your big electromagnet to drive the voice coil.
Everyone has a photographic memory. It's just that most are out of film.
Old 9th April 2006, 01:50 PM   #4
mazurek is offline mazurek  United States
I was wondering similar things, I guess they make servo pneumatic cylinders, besides the fact that you would need a compressor, seems like a cool way to push a cone.
Old 9th April 2006, 02:28 PM   #5
Could 2 hydrolic pumps with very fast valves that open proportional to the low frequency bass be used. This would mean that a much cheaper way of producing power could be used. I.E. and engine?
The valves would have to move at a speed allowing each to open and close more than 100 times per second. Allowing bass up to 50hz.
The fluid would also have be under huge pressure.
If this was possible to make then the bass from it could be almost unlimited as the SA and excursion could be huge allowing for huge bass due to the power available from the engine. There would be no problems with heating except friction.
Just an ideaHide this!Advertise here!
Different pre amp idea bartek Solid State 3 25th March 2008 03:42 PM
I really have no idea what I'm doing here... d to the g Multi-Way 10 7th March 2008 06:04 PM
P.S idea noyan Power Supplies 15 19th December 2007 08:50 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
Copyright ©1999-2017 diyAudio
