Old 30th March 2006, 06:42 PM   #1
Tehrasha's Avatar
Send a message via MSN to Tehrasha Send a message via Yahoo to Tehrasha
Default Insanity HT Horn
In my previous post, I made mention of crazy design for a bass horn to be used as the projection screen in an HT setup. So here it is. If I am correct, this bottoms out around 27Hz. Bracing obviously not shown.
Dimentions == 96"x96"x24"
Throat Area == 144 sqin. (72x2)
Mouth Area == 16 sqft.
Taper Rate == 30"
Horn Length == 126"
Front and Side elevations.
3/4 View
Provided it doesnt collapse under its own weight, I am thinking of using a pair of Assassin 12" drivers for this. Back volume has lots of room to play with. (6 cuft as shown)
My plans on paper have this as two pieces (upper and lower) so it does not have to be build on location, but any way you slice it, its still huge.
Old 30th March 2006, 07:53 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
It's looking good. What software do you use to model horns in 3D?
Old 30th March 2006, 08:05 PM   #3
tade is offline tade  United States
Send a message via AIM to tade
sweeeeet
Old 30th March 2006, 08:49 PM   #4
Tehrasha's Avatar
Those were done with
Blender.
Old 30th March 2006, 08:58 PM   #5
synergy is offline synergy  United Kingdom
so the screen is going to be fastened to it from the top and the bottom edge will be the edge of the mouth correct?
what are you going to do about the center speaker?
reckon with a bit of fudging of dimensions to allow for the box volume you could probably mount it in the box and have it fire directly through the center of the screen
think outside the box
Old 30th March 2006, 10:00 PM   #6
tinitus is offline tinitus  Europe
That sure is a big one
I would say if you skipped that od V-shaped start of "line" - you could tilt that rearchamber and get woofers further down and get a longer loadline - that V-shape have wrong angles anyway - too steep, as far as I can see.
And I think you need a V-shape at top of the last folding
Is this both channels or will there be two of them?
Old 30th March 2006, 10:33 PM   #7
i second synergy. That would be super sweet and I dont think it would be too tough.
Old 30th March 2006, 10:37 PM   #8
Banned
I did that with three horns and three JBL 2242H 18's.
It is good.
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 30th March 2006, 11:09 PM   #9
Tehrasha's Avatar
The angles should be correct. They cut the volume in half over a distance of 30 inches. The 12" woofer sits over a 9.6" hole, which give is a throat area of 72 sqin. (which matches the combined area at the bottom of each side of the ^) and a compression ratio near 1.5:1.
I totally forgot to put the reflectors in the upper corners and the top center. Will have to fix. Thanks!
TWO!? Getting my wife to let me build one will be difficult enough.
I plan to drive it from a bridged amp, fed by the sub-outs on my HT receiver.
Old 30th March 2006, 11:59 PM   #10
rcavictim's Avatar
Magnetar,
Your speakers must image like crazy. Just by looking at the picture I got a sense of it! I thought I was at a ball game.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Ohhh The Insanity! Madmike2 Multi-Way 7 22nd August 2005 05:36 PM
My insanity begins Madmike2 Solid State 4 13th June 2005 10:49 PM
Upgrading into insanity.....(long - sorry) maxg Analogue Source 11 27th May 2004 12:17 AM
Measure T/S.. Insanity check not equal to Fs HELP gjeff80 Multi-Way 7 3rd February 2004 05:15 PM
Audio Insanity? griff Everything Else 1 25th January 2002 05:57 PM
Page generated in 0.11870 seconds (79.15% PHP - 20.85% MySQL) with 11 queries
