I am hearing female singers thru my subwoofer.
Can XO's be bench tested using a signal generator and a scope? It is a old Speakerlab DAS/SW vented 18" cube with a dual coil driver. It has 2 passive crossovers . The output of each crossover is connected to a sub voice coil and a satellite speaker. I have pulled one of the XO's from the speaker so I could get the capacitor sizes for recapping. But I am concerned that maybe there is nothing wrong with the caps and that that is the way it was designed. The woofer voice coil is 6 ohms and the cap leading satellite is 100 MFD. Also both inductors are laying down and their centers are 4" apart. Is that acceptable? Thanks for your help, Victoria |
#2 |
This is likely to happen with 2nd order filters, but it's not neccessarily a bad thing. Both female and male voices have frquency content in the midbass range with components as low as 80Hz, and filter action is progressive.
Of course, you can feed the system with sinewaves at various frequencies and use an oscilloscope to see how much voltage is entering and leaving the filter, but you have to do that test without disconnecting anything from the filter. |
#3 | |
By the way, even in my 2nd order@40Hz sub, I hear voices very faintly. |
| Bench testing a SA/4e | arnyk@comcast.n | Pass Labs | 1 | 6th January 2010 07:43 PM |
| Testing 5651WA on the bench | d1camero | Tubes / Valves | 2 | 30th April 2008 09:16 PM |
| Bench Testing Positive Ground AM Radio | 65blkbkgt | Car Audio | 11 | 27th February 2008 04:08 AM |
| Testing Crossovers w/ unknown component values | THUMP LUMP | Multi-Way | 3 | 16th August 2007 03:41 PM |
| Bench PSU | sorenj07 | Tubes / Valves | 5 | 19th February 2007 10:53 PM |
| Page generated in 0.08378 seconds (75.17% PHP - 24.83% MySQL) with 10 queries |
