Old 25th March 2006, 01:52 AM   #1
Default Mcm 55-1465
I'm still trying to find some who has used and measured the
MCM 55-1465.
Old 28th March 2006, 04:13 PM   #2
http://users.ece.gatech.edu/~mleach/satspkr/
/sreten.
Old 28th March 2006, 04:31 PM   #3
Thanks for the response. I think that article was published a long time ago. It states that the Vas is 4.80 cubic feet. The current MCM published specs state that the Vas is 7.20 cubic feet. That's a big difference. This is part of what has generated my uncertainty. They both have the same part number, but I think the speaker has been changed.
Old 20th September 2010, 12:16 AM   #4
Default 4 of these in isobarik configuration?
These drivers claim 93 db / 1 watt.
If I put two pairs of them in isobarik configuration (4 drivers total) it seems to me that I can use a linkwitz transform to get them flat to 30 hz with no problem. I almost never listen to music that loud (93db) so it appears I can eat up a lot of power handling using the transform, right? And with that power spread among 4 drivers they should handle it with no sweat...
Any technology sufficiently advanced is indistinguishable from magic
Old 28th January 2012, 05:17 PM   #5
I finally got around to measuring one of these. If anyone is interested I'll post the results.
Old 13th March 2012, 01:02 AM   #6
Let's see 'em .
Old 13th March 2012, 03:04 PM   #7
Ok...it has two voice coils, 4 ohms each.
This is with both coils in parallel:
Re=3.302
Le=1.203
Fs=23.55
Qts=0.317
Qes=0.356
Qms=2.869
Vas=6.645 cu ft
This is with one coil:
Re=6.373
Le=1.289
Fs=23.55
Qts=0.535
Qes=0.663
Qms=2.767
Vas=7.013 cu ft
Old 13th March 2012, 07:28 PM   #8
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI:Not isobaric but someone might find this is an useful simulation :
b
Old 15th March 2012, 06:17 PM   #9
Shucks, I thought you meant frequency response and impedance measurements. Thanks, in any case.
Page generated in 0.09382 seconds (71.62% PHP - 28.38% MySQL) with 10 queries
