Old 23rd March 2006, 04:38 PM   #11
Jose_L is offline Jose_L  United States
soloxp,
Yes that's the place, but I'm told they are backorderd. Don't really know yet.
If they aren't in stock then I'll go w/ the SS RL-p15's ... Just not sure if to get the 500w BASH or the 1000w Dayton plate amp..
Also someone told me that 2 - 12" from O Audio would be better than 1 - 15" if I decide on only one driver/box.. Soo many options..
Jose
Old 24th March 2006, 03:37 AM   #12
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
BA, crossing at 40 Hz will minimise the damage but it is still there. 2nd and 3rd order distortion products are in a more critical range - 80 and 120 Hz. I think there are better value drivers out there. I'd be more interested in those sound splitter drivers, ascendant audio or rythmik audio.
I am planning on building a very large bass horn to try to get some real accuracy out of my AV12s (it just so happens they model very well in the Lab horn and better in a larger version). Starting from scratch I'd choose different drivers.
Paul,
I'll agree 100% that even crossing low will not solve all problems. distortion below 40hz goes up up up anyhow. The tumult is a very good driver at producing low frequencys with low distortion and I've yet to hear a driver that did a better job.
I dont know how critical Jose's listening tastes are though, so whats best for him is for him to decide. Hopefully our opinions might help him make the right decision
Now if only someone who has used those sound-splitter drivers would chime in and give a subjective report on them!
The golden rule of DIY:
Build nice, or build twice!
Old 24th March 2006, 04:29 AM   #13
"Servo15" , I'm talking about the Paradigm Servo 15 sub..
Right now I cross my center & rears at 60hz and my mains at 40hz.
My speakers are pretty old. I have some Polk SDA SRS2 (mains) and SDA 1C's (rear) and a csi5 center. W/ a AVM20v2 pre and 3 carver TFM amps powering each set w/ the center bi-amped.
I really care about quality bass, because right now I have a Paradigm pw2200 sub and I find it real boomy.. Plus it doesn't fill my room w/ alot of clean bass. 20 x 22 x 10 ft ..
I think I'll go w/ the RL-p15 w/ either a O Audio 500w bash amp or get the 1000w Dayton amp. Not sure what to do..
I'm still considering the 15" Tumult only because it seems to be highly regarded. And I'd like to do this right the first time. But I also see alot of people using the AV15 & RL-p15 ...
One thing, the O Audio Bash amp does have an adjustable rumble filter (12, 16, 20, 25hz) while the Dayton amps 500/1000w have their rumble filter set to 18-20hz.
Is this a big deal in a sealed enclosure ?
Thanks everyone,
BTW, Does anyone sell a 1000w Bash plate amp ?
Jose
Old 25th March 2006, 12:47 AM   #14
paulspencer's Avatar
I mean would the best driver & amp out perform a servo15 sub ?
Possibly, but I wouldn't count on it in most cases, if you mean by "outperform" that it would be more accurate.
I recall a review of a number of subs in which a 4x12" vented Genelec sub seemed to be preferred over a 1x18" sealed velodyne servo - perhaps not a fair comparison but the larger sub managed to get similar distortion (and higher output) with more displacement and a vented design.
If I were you I'd seriously consider a pair of vented Rythmik 12" servo subs. I'd then stuff all vents and cross all speakers at 80 Hz - you will find most vented speakers that go down to 40 Hz (F3) will have a 2nd order rolloff below 80 Hz when converted this way, and it is easy to cross to the sub. Rythmik will provide either a 2nd or 4th order crossover on their plate amps and unlike most plate amps they provide an appropriate rumble filter to protect the driver below tuning.
Those Soundslitter drivers appear to be good, but from what I can tell the Rythmik drivers are just as good BEFORE the servo is added, after which I'd expect noticeable improvement.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 28th March 2006, 12:31 PM   #15
Originally posted by BassAwdyO
Yup... I'd suggest just getting one set for starters and if you decide you need more, you can get it. But if you know you'll want something louder(which I know I always do, but its your personal tastes not mine) then go for two.
They both have almost identical excursion and power handling while the AE driver has a higher sensitivity.... AE wins bang/buck
The AV15 I is our TC2+ which is more like an RL-i, which is a 2" VC. The RL-p is our TC9 which is a simply a more substantial driver in every way. Bigger motor, bigger 3” VC, and has a far better BL^2/Re result.
The TC9 is the TC2+’s bigger brother.
Old 28th March 2006, 01:24 PM   #16
simon5 is offline simon5  Canada
You are right but that AV15 is now at revision number 2 so probably better than RL-i.
RL-p is very good but you get higher inductance and the maximum excursion is not that good.
On the other hand, availability for the RL-p is better
DIYaudio for President !
Old 29th March 2006, 09:20 AM   #17
25mm is not good?
its higher than the TC2/rl-i
TC9 is a far better platform, much higher force2/re product, larger motor, much bigger VC diamter.
Old 29th March 2006, 01:10 PM   #18
Default Re: AV15 or RL-p15 or Tumult 15
Originally posted by Jose_L
Hello everyone,
I settled on a Adire 1200w plate amp. I'm going to make a sealed enclosure
~4.5-5^ft ..
I was going to get the RL-p15d2 driver, but I'd like to make sure it will work w/ the amp I selected..
The RL-p15d2 is $269, AV15180, and the Tumult 15d2 is $600 ..
Which would be the best in a sealed enclosure w/ the amp I selected ?
And which would be the second best (price wise/bang for the buck) ?
Thanks the help.
Regrads,
Jose
Also I'd add the RL-p15 $580 to the drivers under consideration..
So do anyone have an preference on these drivers in a sealed box ?
Considering the ADA amp will cost $600 and the most expensive driver would cost $600 , that's $1200 before the cost of the box itself.
Is it worth it ? Or should I get a Servo15 for $1750 ..
thanks for the help...
Jose
You mean the "RL-s" for 580? Yes, that would easily be the best of the bunch, 3.75" maximum travel with complete linear BL makes for the most accurate super excursion driver on the market.
Old 29th March 2006, 02:26 PM   #19
Send a message via AIM to ssabripo
the current AV15 is under a second revision, MKII, and it is substantially better than the original TC2+ derived one.... I actually have listened to both the RP-L 15 and the AV15, and both are superb, and slightly favored the AV15 just for its visceral effect.
Kyle at TC sounds is right about the RP-L with its XBL^2, but John and Deon Bearded at AE have done a marvelous job of improving the AV15 to what it is now, and it will be hard to find a driver under $300 that can match its performance....PERIOD.
Speaking of, I decided to go with the AV15 for my project (after listening to several drivers, including a pair of LMT-15's), and it is finished:
Click the image to open in full size.Click the image to open in full size.
in a nutshell, it sounds better than my Current SVS PB-12 Ultra!!
Old 31st March 2006, 05:46 PM   #20
Paul W is offline Paul W  United States
Paul W's Avatar
007,
How much pole vent and/or spider noise does the RL-p 15 generate in a dipole environment?
Any Stryke AV15's for sale? jholtz Multi-Way 5 1st April 2010 01:05 AM
Tolerances on AV15 pinkmouse Subwoofers 8 5th August 2006 07:06 PM
AV15 Subs (design & construction) ShinOBIWAN Subwoofers 38 11th April 2006 09:38 PM
Av12/Av15 available? Curt Badry Subwoofers 5 9th May 2005 07:40 AM
AV8 and AV15 Vaic tubes Alain Favret Tubes / Valves 1 30th March 2004 08:04 AM
Page generated in 0.13470 seconds (83.74% PHP - 16.26% MySQL) with 10 queries
