I just ordered all of the parts to build a pair of b3s's (zaph's design). Now I'm trying to find the parts for the subwoofer.
I have no problem starting from scratch, but I have an unused Jensen JS-800 8" subwoofer. The sound quality is awful, but for $50 I got the subwoofer, a MTM center, two TM L/R's and two M satellites. (this was before I cared about sound quality). I am pretty sure the 8" driver from the jensen is useless, but is the 100 watt plate amp still good? I know you guys dont like using existing cabinets, but just in case i could save time, it is a 12" x 12" x 15" with .5" MDF any use? I am looking for 8" driver recommendations, or anything that will match the b3s's. The final product is going to be used for computer speakers in a dorm room. Thank you, BMD (P.S. Happy St. Patrick's Day!) |
#2 |
Take a look at this thread, a mini sonotube subwoofer with the Tang Band W8-740C 8" subwoofer: TB W8-704C mini Sonosub...
It would be right up your alley. I would NOT reuse the enclosure, but the amplifier would be fine to use, and a Sonotube enclosure is not tricky to build. Another driver to consider would be the MCM 55-2421, which is a noname 8" subwoofer with similar specs to the Tang Band (but is a little cheaper). Its been popular because of its decent specs, and low price. peace, sam |
#3 |
why 8's? i say go for a pair Dayton RSS315HF! Should work great for a 2-way system and they can cross over very high for a 12" woofer.
#4 |
Unfortunatly the #1 concern with these subwoofers is their size, followed closely by price. Right now i'm between the Tang Band W8-1363SA or the ascendant audio assassin 8. I want to spend around $50 for the driver.
#5 |
Sorry to revive this old thread but I also am finishing B3S and need to start looking at the sub... I want something cost effective, not horrible in sound quality and to be crossed high at 150hz... Any suggestions?
Should I go for a sub or a just a large woofer? What about these? http://www.mcminone.com/product.asp?...me=MCMProducts http://www.partsexpress.com/pe/showd...number=264-854 http://www.partsexpress.com/pe/showd...number=295-550 http://www.partsexpress.com/pe/showd...number=295-490 http://www.partsexpress.com/pe/showd...number=295-315 http://www.partsexpress.com/pe/showd...number=295-320 EDIT: also interesting http://www.billfitzmaurice.com/T18.html |
#6 |
frugal-phile(tm)
Some of those are pricey enuff that you could be considering the CSS SDX7. We are playing with them in conjunction with the µFonken with the 3" Fostex FF85j. Our current experimental unit is, i believe, being limited by the cheap plate amp. We are going to build another to try different amps.
I'm also working on tweaking the driver for better performance. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
I'm sure the more I spend, the more I get in return... but I really want to keep it low... 100$ is too much... at that price I would spend a little more for the Dayton RS 12" and a bigger amp but that would be another project all together... Keep in mind that this sub is to be matched to the 12$ Hivi B3S...
#8 |
Update... a few more options:
http://www.apexjr.com/speakerstuff.html Eosone 12" or Apex Jr Super 8" |
#9 | |
IF you have B3S's you can maybe hit 100dB on a good day so you don't really need much for a sub, IMO, unless you are the type who likes to have the bass boosted 40dB above the midrange. IMO a decent 8" woofer with a 40Hz cutoff is good enough, but a 12" isn't out of the question if you just have to have 20Hz. This isn't rocket science. You could use a Cabasse or several other types if you like the inverted dome shape of the HiVi's.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#10 |
Has anyone worked with this: http://www.mach5audio.com/product_in...84c6dab21fc73b
It looks interesting but would appreciate feedback from actual users... or this one: http://www.edesignaudio.com/edv2/pro...products_id=29 |
| subwoofer feedback system | mazurek | Subwoofers | 2 | 7th August 2006 10:27 PM |
| how to connect a non powered subwoofer to a stereo system without a subwoofer output | JSD777 | Multi-Way | 4 | 20th September 2005 03:19 PM |
| Stereo system with Subwoofer, How to do it? | py | Everything Else | 5 | 13th January 2005 07:25 AM |
| Sealed subwoofer system | smithsonga | Subwoofers | 29 | 24th July 2003 05:59 PM |
| Page generated in 0.11164 seconds (80.53% PHP - 19.47% MySQL) with 10 queries |
