Hey guys. I'm a little new to HT. I have been building seal boxes for over 10yrs...But never builded a ported box and never use a program to build boxes. I have been in car audio for 14yrs and only used kicker subs.....because they put out some deep bass. I builded a box which is external dimensions (H-22) (W-25) (D-17) to get internal volume of 4.3 cu ft. I made it down firing with 4" 13" long port. I need help tuning it to 18-20 Hz. It shakes the whole house damn nice. I went to fry's this weekend and pickup a Velodyne DLS-5000R. Man...I must have gotten a bad one...because my sub blows it away. And I have this amp from partsexpress 300-796
Thanks |
#2 |
Did it Himself
For 20Hz with a 4 inch vent in that size box your vent needs to be 17.64 inches long.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Sorry i for got to put what sub i'm using. It's a Kicker comp15" 2005
Here the info...http://www.kicker.com/06/tech-suppor...b%20Manual.pdf I tryed to edit but i didn't see it. |
#4 |
Speakerholic
The edit button is at the bottom of every post you make but is active for about 1/2 hour only. After that you have to ask us. This one's fine.
#5 |
Wow that was quick guys. Thanks for the quick reply richie00boy. I will give that a try as soon as i get home today. Also what you think about this amp from O Audio. http://www.oaudio.com...was thinking about picking 1 up Friday. I like that it has (Room mode control parametric equalization) and Selectable low end EQ/subsonic filter.
#6 |
If you can put the port on the 25" side or 22" side, I would use this, you don't cut it, keep it full length :
http://www.partsexpress.com/pe/showd...number=268-352 You would get less port noise, and get 20 Hz tuning point too. BTW, with which software do you calculate port length richie00boy ? BTW, your link doesn't work soloxp. Oaudio seems to make good amps afaik.
DIYaudio for President ! |
#7 |
Sorry about the link....here it is.
I made the port 4" 17.64 long and it did make a big diff. Hey simon5 so should i make it 22" long instead of 17.64". I took back the Velodyne and got a new one...but know diff. This thing will kill the Velodyne DLS-5000R. http://www.oaudio.com Also here is the box that i built and amp. http://home.austin.rr.com/soloxp/images/pic/2.JPG http://home.austin.rr.com/soloxp/images/pic/4.JPG |
#8 |
No no, the port I recommended using is 18" long, but flared so it's acoustically 17" long.
I just wanted to say that you couldn't install it on the side measuring 17" deep. You will have less port noise with a flared port like that one. BTW, I wanted to add that your box is a bit small for the C15 in a home environment. A better box would be 8 cu.ft tuned to 20 Hz. Huge, I know.
#9 | |
Did it Himself
#10 |
Hey simon5..I was thinking about that when i was building the box....but i would got kick out the house.
I still need to know if this amp is a good one to get. Or is there somthing better then this around the same price. http://www.oaudio.com Thanks |
| I got your 20Hz-20Khz Right here !!!! | sumsound | Multi-Way | 21 | 19th August 2008 07:45 PM |
| Need 20hz subwoofer | Tiggerfip | Subwoofers | 4 | 9th April 2004 02:37 AM |
| 20hz-20Khz | Solid Snake | Multi-Way | 18 | 4th February 2004 07:08 PM |
| Page generated in 0.11099 seconds (82.71% PHP - 17.29% MySQL) with 10 queries |
