#31 |
Nice work Shin. I never knew you were a closet bass nut
I know too much is never enough, but are you sure these aren't overkill ? I would have thought 1 sub would have been enough. Corner placed, a single one could probably reach 115dB at 20Hz!! |
#32 |
Did it Himself
Nice work again Ant, hope you get better soon, but give up that dirty habit!
We looked at using the BK module for our sub, but in the end made our own complete plate amp with LT and everything, measuring just 12"x12" If you need any help with the LT or measuring the driver etc just give me a shout, I have written a good guide on measuring T/S parameters.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#33 |
Al
I'm confused I took voltage reading and the 2 core wire had 5v - isn't that a bit much for a low level signal? The 3 core looks to be the correct one but I measure 16-17v. How do I figure out which is ground BTW? I did measure around 33v when I was messing around switching between the connections. Also, the large ceramic resistors that you can see in the pics on the last page get extremely hot. This is safe I presume? |
#34 | |
The lowball looks nice, good work on that. This TS guide you've written; is it any easier or more accurate than a moderately well calibrated Speakerworkshop setup? This is what I use at the minute but would be interested to take a look at another way. Please send me the details to: zeroex_15 at hotmail . com |
#35 | |
I don't really listen at 100dB much let alone 115dB, what I'm aiming for is a natural extension to develop the Perceives into a 3.5way almost or rather a limited bandwidth 3-way with subs. The Perceives will happily reach down to 40hz but after this there's very little in the way of bass. This is where the AV15's will take over for stereo listening and offer stereo bass of course. They will be connected via highlevel for this. For movies I'll just use both on the LFE channel via low level. The BK amps are quite flexible and offer level controls for each input. I think the main advantage of 2 subs is stereo bass for music and reduced distortion. |
#36 | |||
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#37 | |||
Thanks for the ground tip. Quote:
I would have spaced them out a little more but its all guaranteed and should it fail then BK are said to have very good after sales. |
#38 |
#39 | |
Now why didn't I think of checking the manufacturer's website for information on its products? |
| trying to design Subs. | dlp5135 | Subwoofers | 2 | 15th October 2008 09:13 PM |
| Fountek & Peerless Design - Construction Details Inside! | soundengine355 | Multi-Way | 12 | 6th August 2008 02:14 AM |
| JX92 + Alpha 15 OB - Design & construction | dviswa | Full Range | 22 | 6th June 2008 05:53 PM |
| Av12/Av15 available? | Curt Badry | Subwoofers | 5 | 9th May 2005 06:40 AM |
| Page generated in 0.10558 seconds (84.11% PHP - 15.89% MySQL) with 10 queries |
