Flared Ports Part 2
Flared Ports Part 2
Old 9th March 2006, 08:07 AM   #1
Collo is offline Collo  Australia
Collo's Avatar
Send a message via MSN to Collo
Default Flared Ports Part 2
About 6 months ago, I posted results of testing flared ports for turbulence.
The discussion ran for 6 pages in the following thread:
http://www.diyaudio.com/forums/showt...528&highlight=
That work described how increasing flare size allowed a higher velocity to be used before turbulence became audible.
Since then, I've built some larger boxes and more ports, allowing me to discover where this effect "rolls off" as "core" turbulence takes hold. Additionally, I've found that port performance varies with frequency.
All the findings, along with a much improved "Flare-it" calculator can be found at the original URL:
http://www.users.bigpond.com/bcolliso/index.htm
I hope you all find it useful, and I look forward to the discussion...
regards
Collo
Ports rule!
Old 9th March 2006, 09:25 AM   #2
Collo's Avatar
whoops,
that link is to the homepage
the one for the tests is:
http://www.users.bigpond.com/bcolliso/flare-testing.htm
Collo
Ports rule!
Old 9th March 2006, 10:46 AM   #3
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
Great work Collo!
Old 10th March 2006, 09:45 PM   #4
Collo's Avatar
Thanks Paul,
thanks for that comment.
Here's an example of how the new calculator can be used .....
In the original thread you asked:
Can this be right? I entered a 100mm vent with 72mm flare radius and it says 42.9m/s is ok!!!
my best answer at the time was:
There is of course the principle that the unflared section of the port also has a speed limit.
"Flare-it" now provides a much better answer:
The limiting velocity for a 100mm diameter port is 29 m/sec @ 30hz, and 19 m/sec below 25hz.
To control boundary turbulence up to these velocities, a 44mm flare is required - there is no advantage in going any larger!
Collo
Ports rule!
Old 10th March 2006, 10:26 PM   #5
phillfyspoon is offline phillfyspoon  United Kingdom
cheers your programs are of great help
Old 11th March 2006, 04:17 PM   #6
Hi collo Could I have a chat with u on msn my addy is phillfyspoon@msn.com
want to talk about flares
Old 11th March 2006, 10:32 PM   #7
Collo's Avatar
Done. That MSN Messenger makes things so easy.....
Ports rule!
Old 13th March 2006, 05:13 PM   #8
hi collo
Im poor at maths could u workout what mold i need to heat mold 25mm flares on a 6inch port
Old 13th March 2006, 09:22 PM   #9
Collo's Avatar
Cut three MDF disks to the same size as the internal diameter of the pipe. Screw the first disk to a baseboard. Screw the next disk to the first one, end then the last one to that.
I usually calculate the exact size of the disks to minimise the amount of filler required, but for a 25mm flare, the savings are minimal.
Cut a 25mm disk from whatever material you have available to use as a scraper.
Ports rule!
Old 21st March 2006, 10:36 PM   #10
Hi Collo
Been alittle busy but got everything I need
I found something that might act as a mold for me but does the shape of the flare matter?
this is what the shape will be like:
Flared Ports Part 2Hide this!Advertise here!
Making Flared Ports CBFryman Subwoofers 17 3rd March 2013 12:45 AM
6 inch flared ports thylantyr Multi-Way 25 15th January 2008 05:04 PM
Flared ports and turbulence Collo Subwoofers 59 21st November 2005 11:17 AM
For those interested in flared ports... f4ier Multi-Way 0 26th May 2002 04:47 PM
Copyright ©1999-2017 diyAudio
