Old 5th March 2006, 11:57 AM   #1
fish4u is offline fish4u  Philippines
Default 60"
have anyone of your happen to see this?
60" subwoofer
im gonna leave you with your thoughts now.
Old 5th March 2006, 12:06 PM   #2
bigwill is offline bigwill  United Kingdom
They should put it in a horn
Old 5th March 2006, 04:11 PM   #3
Speakerholic
Cal Weldon's Avatar
That one seems to have been around for a bit. Haven't heard anything recently but it is novel isn't it?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 6th March 2006, 06:54 PM   #4
Send a message via MSN to xstephanx
The horn woudl need to be made out of like, iron reinforced foot thick concrete......but boy would it be DAMN loud....if you could somehow fit itonto the back of an 18wheeler...firing into the cabin.....and they say 180db is next to impossable.
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!!
EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!!
Old 8th March 2006, 07:47 PM   #5
KBK is offline KBK  Canada
The dark horse:
Thre may be a commercial system available soon that is far less ridiculous..but also -still- insane. stay tuned.... (not from me!). Ie, actually available for purchase and proper use. Whatever that means.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 8th March 2006, 09:13 PM   #6
Speakerholic
Cal Weldon's Avatar
Originally posted by xstephanx
Tand they say 180db is next to impossable.
It is next to impossible.
If that thing can create those sorts of figures you could de-feather a chicken while listening to it.
Old 9th March 2006, 05:33 AM   #7
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
There were no specs given on that sub except excursion and cone area. power handling/efficiency(electrical and mechanical) are much more important. Next comes thier vehicle's rigidity....
180db is easy for say... a space shuttle
The golden rule of DIY:
Build nice, or build twice!
Old 9th March 2006, 10:46 AM   #8
paulspencer's Avatar
I think they are talking about within an enclosed space. Much easier than in free air.
Why would 180 db be impossible?
Surely enough displacement and power should be able to do it.
Lets say we want to do it with some stacks of horns.
1w >>> 105db
10w > 115db
100w > 125
1000w > 135
Double the drivers and amps > 141db
4x 147
8x 153
16x 159
32x 165
64x 171
128x 177
Ok of course this is crazy. But is there any reason why this could not be done with excessive power and a huge stack? I have no allowed for power compression, but with the larger stack they will handle more power and have more directivity.
I'm a little suspicious of this single subwoofer being able to equal the output of 128 massive bass horns, it does sound like a bit of a stretch don't you think?!
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 9th March 2006, 05:24 PM   #9
BassAwdyO's Avatar
very much so
Old 9th March 2006, 05:41 PM   #10
It does,
But consider that dB-drag is done with bursts that are much higher as the rms-powerrating, also in this short time powercompression isn't much of an issue.
With a stack of horns sensititvity raises with 3 dB/ doubling only within a 1/4 wavelength. A stack of 128 would be to big to achieve this.
You might find some of the replies of interests: http://srforums.prosoundweb.com/index.php/t/11681/0
Wkr Johan
Impossibilities we do immediatly, miracles take slightly longer.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Charcoal "Supreem" hi-density foam "enclosure" IG81 Multi-Way 0 23rd April 2009 01:34 PM
What Does Fostex "Rated Input" and "Music Power" mark02131 Full Range 3 2nd January 2007 08:31 PM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 06:07 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 08:42 AM
Page generated in 0.10640 seconds (77.72% PHP - 22.28% MySQL) with 11 queries
