I am looking for a pair of cheap. let me reiterate CHEAP!!! 12" 70watt 8ohm drivers.
can someone hook me up with a good site? this is for a sub-woofer modification for a vented two speaker sub-woofer box from a car audio system. I have already purchased my amp from apex jr. I got the Cerwin Vega ARPHU2003 SubWoofer Amp rated at 150 watts. I am not sure how this will sound in my home audio setup but I think that it will be more than enough for my needs. I don't listen to much music but would like that good thump while watching movies. I know that it would be better with a more powerful amp and some 100 watt speakers. please don't be to harsh of my plans. |
#2 |
I'm sure http://www.partsexpress.com has something to fit your budget
#3 |
thanks for the link. I think I found a good 12"
just want to ask to make sure this would be good for my application the DAYTON DC300-8 12" CLASSIC WOOFER rated 8 ohm 80 watts If I use two of these with my 150 watt amp everything should work ok right? I think that this setup is optimal as the two speakers will equal 160 wats giving me a 5 watt per driver leway. Im not sure about this stuff so your input is appreciated here is a link to the driver http://www.partsexpress.com/pe/showd...number=295-320 |
#4 |
you need to specify the internal volume of your box to get any sensible advice. The power handling if the drivers is not really the issue. The issue is being able to use your 150W without excursion limiting. |
#5 |
you may want to consider this
http://www.partsexpress.com/pe/showd...number=295-470 the 15" has a lower fs ,more power and xmax.you should get lower bass for movies.you really should be looking at subwoofers and not woofers for movies.but if money is really tight you can't go wrong with the daytons |
#6 |
For what you want to do this would be much better for the money Id probaly go with one of these with the amp you have This would be much more suited for movies as it is a subwoofer It has almost twice the xmax of the previously mentioned wooffer and a fs of 25 hz In the proper enclosure this would give you your requested bang for the buck.
http://www.partsexpress.com/pe/showd...number=295-490
WHAT ____________ |
#7 |
I also failed to mention that the efficiency of the shielded dvc 12 is 94 db compared to 91 for th eclassic wooffer this along with the xmax advantage maeans that 1 shielded dvc 12 would be very comparable (on the same 150 watts ) to 2 classic 12 inch woofers and probalby much better suited for a subwoofer and cheaper
WHAT ____________ |
#8 |
MCM 55-1465
It's on sale now for $30 with the code. http://www.mcminone.com/product.asp?...5Fid=55%2D1465 |
| Cheap 6.5" drivers | PeteMcK | Multi-Way | 42 | 1st January 2009 08:11 AM |
| Decent Cheap 6.5 " FR drivers. | dpuopolo | Full Range | 3 | 16th September 2007 11:36 AM |
| 8" drivers (cheap)? | mr. doom | Multi-Way | 4 | 2nd December 2006 08:55 PM |
| WTB: 269-469 ("1$ Parts Express") drivers, or other really cheap FR drivers. | Spasticteapot | Swap Meet | 1 | 5th November 2006 03:31 PM |
| Page generated in 0.10381 seconds (79.47% PHP - 20.53% MySQL) with 10 queries |
