vented tube design for small driver
Old 27th February 2006, 09:01 PM   #1
jarrettl is offline jarrettl  United States
Default vented tube design for small driver
I've just purchased an 8" dayton dvc and 100w plate amp to put in a .5 cu.ft. box i already have. It would be a front-firing ported enclusure. However, I've been reading about uses of sonotube and was wondering if I could use a segment of sonotube to (seriously) extend my box volume, say, like this.
Would this cause any weird problems? I have modeled it in WinIsd and graphs look good. I would be downfiring instead of front firing. Is a 5.2% sag acceptable? Am I just some math and a couple feet from a TL? Would an 8" driver be acceptable for a small TL using 8" diameter sonotube. Some advice would be helpful as I am very new to this. Powered Sonotube TL?
Old 27th February 2006, 09:54 PM   #2
simon5 is offline simon5  Canada
Usually 5% sag is the limit, so I guess it would be ok...
A TL with a 8" driver? Many people do that.
DIYaudio for President !
Old 27th February 2006, 09:57 PM   #3
tade is offline tade  United States
Send a message via AIM to tade
can you use a dc current to prevent cone sag?
Old 27th February 2006, 10:15 PM   #4
Not recommended AFAIK.
vented tube design for small driverHide this!Advertise here!
small(15l) vented bipole with fe127e, possible? Brytnardz Multi-Way 4 8th June 2008 06:58 AM
David: Small vented loudspeaker with bass boost Dominique Multi-Way 4 21st May 2008 03:17 AM
Small vented TB W4-656 speakers BoomieMCT Full Range 1 10th May 2007 04:17 AM
Very small vented speaker? noobsta Multi-Way 3 9th December 2005 06:05 PM
Ported Enclosure Design w/o Driver Theil-Small Parameters misterbobman Multi-Way 6 29th March 2005 02:06 PM
Copyright ©1999-2017 diyAudio
