Need Good Drivers in India!!!
Old 23rd February 2006, 08:24 PM   #1
Arunkumar14_th is offline Arunkumar14_th  India
Default Need Good Drivers in India!!!
Hi Guys,
I'm a newbie in the field.
I have a burning desire to build my own Sub. But i'm unable to get a driver here in Bangalore with published T/S parameters.
Pls let me know where I could find a good driver with relatively high Qts.
Old 23rd February 2006, 10:01 PM   #2
simon5 is offline simon5  Canada
I think some Peerless drivers are made in India.
Check there, they publish T/S.
DIYaudio for President !
Old 24th February 2006, 06:18 AM   #3
Iron-Wizard is offline Iron-Wizard  United States
Iron-Wizard's Avatar
I though Peerless was a European company?
They not made in Sweden or Norway or something like that? i could have swore i saw this on a pair of woofers i had, i will double check.
Tap or Snap, it's up to you.
Old 24th February 2006, 01:59 PM   #4
ashok is offline ashok
ashok's Avatar
Confusing...............even after knowing the details !
There is a Peerless-India ! Made in Mumbai and supposedly made some low end drivers for Peerless of Europe. At least they used to .
How they use the Peerless in their name and are NOT supposed to be affiliated with the original Peerless I do not know.
Try contacting them
AM
Old 24th February 2006, 04:52 PM   #5
Where could i get these drivers?
Any contact info about Peerless in India?
Old 24th February 2006, 07:19 PM   #6
http://www.peerlessaudio.com/contact...n3.asp?cname=1
Peerless Fabrikkerene (India) Ltd.
Postal Address 19, Seepz, Andheri (East)
Mumbai - 400 096
INDIA.
Telephone 91-22-28290834
Fax 91-22-28290422
General Info. info@peerlessaudio.com
New Products enquiry@peerlessaudio.com
Old 25th February 2006, 11:16 AM   #7
sumit is offline sumit  India
sumit's Avatar
I had tried to contact them by e-mail twice, but they did not respond. Moreover I heard from some one that even if they contact you they won't be selling units in india specially low quantities
Old 25th February 2006, 12:08 PM   #8
ashok's Avatar
.............they did not respond..........
Hmmm................think we heard that one many times earlier !
AM
Old 25th February 2006, 12:58 PM   #9
Samuel Jayaraj is online now Samuel Jayaraj  India
This topic has been discussed in this forum earlier. You have not searched enough.
However, to help, let me state that Peerless in India did have a tie up with Peerless of Denmark. That was then and there is no tie up of any sort, now.
You may see that the logo is different for each of these companies.
Peerless India is continuing with some of the old models they used to produce for their principals then. Perhaps, they've added other models which have little to do with the original company's current products.
Those of you in India, if you are looking for some good drivers (Silver Flute Woofers+Hi Vi Research Dome Tweeters+LEAP designed Crossover with quality parts- all supplied by Madisound) PM me directly.
Sam
Old 25th February 2006, 02:23 PM   #10
Guys, I think i found a decent driver here in Bangalore!!
What do you guys think about DAPIC?
Here are the parameters for Dapic DP-1211 (12 inch driver):
Fs - 30.23 Hz
Qts - 0.24
Qes - 0.25
Qms - 4.92
Vas - 70.38 liters
Re - 1.6 Ohms
Le @ 1Khz - 1.61 mH
Xmax - 35mm.
Sd 539 cm2
RMS - 400W
Please let me know if i can go for this one.
Need Good Drivers in India!!!Hide this!Advertise here!
Good drivers in INDIA? goldyrathore Multi-Way 94 17th December 2008 06:02 AM
Want 18" Drivers- In India MatrixElect Swap Meet 10 15th January 2005 06:18 PM
