My 6,5" Westra driver? What can i do with it? - diyAudio
Old 22nd February 2006, 02:47 PM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Default My 6,5" Westra driver? What can i do with it?
Hi all,
I have a Westra KW160-1374 (in fact a pair of) bass speaker. And i want to make a little subwoofer with it. I will drive it a 50W power amp and of course a sub xover. I also want it in tiny sizes and have a lot of deep bass.
What do you recommend about that project? What kind of box must i use for it?
Thanks a lot for your recommendations..
Old 22nd February 2006, 03:21 PM   #2
Did it Himself
richie00boy's Avatar
Thiele-Small parameters needed...
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 22nd February 2006, 04:34 PM   #3
Speakerholic
Cal Weldon's Avatar
This is all I could find through Google:
16cm Tiefmitteltöner
Beschichtete Papiermembran, inverse Kalotte, Gummisicke.
In 4 Ohm jetzt wieder lieferbar!
Technische Daten:
Belastbarkeit: 50 W-RMS / 80 W-Max
Impedanz: 4 Ohm
Schalldruck: 85 dB
Frequenzbereich: 45-4000 Hz
Resonanzfrequenz fs: 45 Hz
Gesamtgüte Qts: 0,5
Äquivalentvolumen Vas: ca.25 l
Einbaumaße:
Außendurchmesser: 165 mm
Einbaudurchmesser: 148 mm
Einbautiefe (incl. Korb): 76 mm
Korbrandhöhe: 4 mm
planet10 needs your help:
Let's help Ruth and Dave
Old 22nd February 2006, 04:44 PM   #4
Did it Himself
Qts is quite high, would need a fairly large box for vented use, so I'm afraid tiny size and deep bass are out of the question - you're going to be looking at around 30 litres.
Old 23rd February 2006, 07:01 AM   #5
Dxvideo's Avatar
I guess 30lt is ok. As i calculated in Winisd; with 50lt box F3 will around 32Hz.. Do you think its deep bass? Will i satisfy?
Old 23rd February 2006, 08:23 PM   #6
simon5 is offline simon5  Canada
Maybe, maybe not, try it!
There's limits as what you can do with 6.5s.
DIYaudio for President !
Old 25th February 2006, 08:24 AM   #7
Dxvideo's Avatar
I'm not good at wood works so will go to a carpenter to make the box! Sure i will try it but i want to have an idea that how it works? Will it be like my Jazz 9940 speaker's subwoofer? What do you think?
Old 25th February 2006, 09:14 AM   #8
12 Cents's Avatar
Default a suggestion
Transmission line... just a suggestion, 1m high, folded 1 time, diameter decreasing from driver to opening.
Old 25th February 2006, 10:20 AM   #9
12 Cents's Avatar
or for the sub, you may want to make a bandpass and mount the two drivers like this:
+----EEEEEEEEEEEEEEEEEEEEEEEEE----------+
Best,
Lukas
Old 25th February 2006, 10:54 AM   #10
Did it Himself
A 6.5 inch driver will never be a sub, no matter how low the graph on WinISD says it will go. This is simply because to get low bass you need to move a lot of air.
westra box help! umut1001 Multi-Way 21 11th October 2008 11:14 AM
Westra KW-200-1338: Usable drivers, or junk? KozmoNaut Subwoofers 3 30th August 2007 11:46 AM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
A Pair of Westra XW-165-1394.. Dxvideo Subwoofers 7 7th July 2005 05:46 PM
Copyright ©1999-2017 diyAudio
