2 subs one box/2 subs 2 boxes
Old 21st February 2006, 08:58 PM   #1
vetkilr is offline vetkilr  United States
Default 2 subs one box/2 subs 2 boxes
Would a box with 2 subs sound the same as 2 subs in two seperate box's if the Cu ft were the same....ie:
2 subs in a 3.0 cu ft box be the same as
2 sub in a 1.5 cu ft box ea.
Also would the power output be the same as in would they handle the same power in either config.
Im building a 4th order box with 2 subs and want to know if I should build it with 2 sealed box's of smaller cu ft or put them both in a bigger cu ft box as I need to know if they would handle more/less power and if they would hit lower in one config. or not.
Hope Im sayin it right.
Joel
subs rule
Old 21st February 2006, 10:39 PM   #2
JRace is offline JRace  Canada
One very big benifit to using two seperate boxes is the abilit to place them in different locations in your room. This allows you to better smooth out the in room response.
Old 21st February 2006, 11:36 PM   #3
I agree with that.
But this is for a car trunk,sorry forgot to state that.
subs rule
Old 22nd February 2006, 12:10 AM   #4
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
It shouldn't make much difference but you can tell. I think it has more to do with the different panel sizes than anything else. IMHO.
planet10 needs your help:
Let's help Ruth and Dave
Old 22nd February 2006, 12:43 AM   #5
simon5 is offline simon5  Canada
Default Re: 2 subs one box/2 subs 2 boxes
Originally posted by vetkilr
[B]Would a box with 2 subs sound the same as 2 subs in two seperate box's if the Cu ft were the same....ie:
Yes
Yes
DIYaudio for President !
Old 22nd February 2006, 09:27 PM   #6
Thank u much guys.
subs rule
2 subs one box/2 subs 2 boxesHide this!Advertise here!
subs dynamixsound Subwoofers 1 28th April 2007 09:47 PM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
2 subs vs. 1 darin Multi-Way 16 8th December 2003 11:02 PM
Subs: Little Boxes, Big Pipes peted Multi-Way 2 28th April 2003 10:15 PM
