Old 17th February 2006, 08:49 PM   #1
johsti is offline johsti  United States
Default isobaric 6.5" subs - newbie
Hello,
I have 2 older jlaudio 6.5" subs (4ohms SVC). They are in good condition and just sitting around taking up space. I also have some 3/4" mdf taking up space.
I have made some sealed car audio enclosures with mdf and fiberglass, but that's about as far as my speaker building experience goes.
what do you guys think about running the 2 6.5"'s in an isobaric configuration? I'm sorry, I don't know the specs on the speakers. I looked on winisd and modeled them based on the JLaudio 6w1. I could be way off, but thought I could start there.
I know nothing about isobaric. How would I wire the speakers (out of phase?)? How powerful of an amp would I need? I was looking at some plate amps at PE. With a sealed enclosure, where should the subs be placed (one in front, and one in back magnet out, etc.)?
I'm looking at this project as nothing more than something to kill time, and learning something new. My expectations are low, but if I can make a decent little sub for music listening I would be happy.
Any insight, input, advice is appreciated. I would like to put these speakers to use rather than trashing them. In the meantime I will continue to search the forum.
Old 17th February 2006, 10:08 PM   #2
Volenti is offline Volenti  Australia
I see little point in using these subs in an isobaric configuration, they already only need tiny enclosures , you are simply throwing away 6db for no real gain.
If they are W-0's then they will respond nicely in vented, attached specs from BassBox6 Pro;
Old 18th February 2006, 09:01 AM   #3
Thanks for the feedback. I'm not even sure if these are the w-0's. There are no serial numbers or anything except for jlaudio on the magnet. All I know is I purchased them used in 1994.
Are you suggesting one vented enclosure with two subs, or two vented enclosures with a sub each?
Old 18th February 2006, 09:21 AM   #4
before you can DESIGN an enclosure you need the T/S parameters.
Learn how to measure them and go do it.
regards Andrew T.
Old 18th February 2006, 04:17 PM   #5
heresie is offline heresie  France
Since the T&S paramters are not the same (even if fs/Qts and Vas.Qts^2 is almost constant) you should use two enclosures or one with 2 compartments.
Avi
are bandpass subs passe compare to "horn-sub"? freddi Subwoofers 9 30th September 2007 07:54 PM
replacing 12" sub in box with back speaker mounted 6" subs aussiebuddha Car Audio 7 14th October 2006 08:26 PM
Convert floor standers to subs with Tang Band 8" subs? prerunnerv6 Subwoofers 3 26th February 2006 12:44 AM
Isobaric for subs only? speekergeek Multi-Way 8 13th January 2004 03:15 AM
Isobaric 8" expectations?! Rarkov Multi-Way 18 12th September 2002 02:41 PM
Page generated in 0.07578 seconds (74.57% PHP - 25.43% MySQL) with 11 queries
