Old 16th February 2006, 11:41 AM   #1
Hayden is offline Hayden  Australia
Default How to tune a sub box
I’m totally new to this whole speaker design thing.
I have a setup their car subs but for home use see photo below it’s the box with the 2 12” subs in it, the box was designed for 2 10” subs but I put 2 12” in it and it sounds crap how do I tune it? Is it possible for the 2 12” to work? Do I just start adding cloth to get the box volume smaller? It’s a sealed box with no chambers.
Old 16th February 2006, 11:56 AM   #2
Did it Himself
richie00boy's Avatar
There's not a lot you can do really in all honesty other than adding EQ circuits or build another box.
Please clarify what your issue with the sound is - there is an extremely small chance that venting the box may help.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 16th February 2006, 12:53 PM   #3
I could get over 40mm peak to peak travel out of them at low frequencies but playing bass cd’s and techno the cones move allot but not much bass my black 10" there in the photo has nearly as much bass as they do.
Old 16th February 2006, 12:55 PM   #4
I’m not really after sound quality just low bass. the box has no bass.
Old 16th February 2006, 01:20 PM   #5
Did it Himself
Maybe you wired them up out of phase then. Make sure + and - are wired the same way on each speaker.
Old 17th February 2006, 06:30 AM   #6
Iron-Wizard's Avatar
You may infact be running everything out of phase so you will get no bass at all,
check all the woofers cone movment with a small voltage source, you only need say 5 volts and mark the positive and negative terminals on all your speakers.
one question, Why do you have so many woofers in your room?
If you want more bass just replace the 10 inch cones in your 3 way floor stanind speakers or run one woofer in a corner.
The more speakers you run from one amplifier the worse the sound quality gets and you will only fry the amplifier.
from the looks of things you have a 0.5 to 2 ohm load on your poor amplifier.
Tap or Snap, it's up to you.
Old 17th February 2006, 10:07 AM   #7
It sounds like its out of phase but its not.
I’m a bass freak after low bass lol you cant kill my Yamaha amp
I’m going for one sub I’m selling them and making a real subsonic woofer low frequencies like 10hz or so.
I have reversed the phase it also depends on the signal you get good bass at a certain hz; then at another you don’t but you can reverse the phase and get it good again its weird, I used a frequency sweep and test tones I made.
4 ohm loads just using rears and canter for the subs
Old 17th February 2006, 10:09 AM   #8
lol should cut them out and put 2 15" in there. See how that goes
Old 17th February 2006, 10:15 AM   #9
kinser is offline kinser  Israel
kinser's Avatar
Send a message via ICQ to kinser Send a message via MSN to kinser
Hayden,
You siad that you are running the subs from the rear and center speaker outputs, thats the problem!
You have to run the subs through a seprate amp with a low pass filter. maby get a plate ampfrom www.partsexpress.com they dont cost much.
BTW how old are you?
Kinser
Old 17th February 2006, 10:34 AM   #10
I’m turning 21 soon, I’m running the second cd player to the third device which is a amp to drive the towers and a 10” sub on the rear channel then it goes into the bottom amp to feed the 2 12” subs they all get good power.
But when I hook up the single 12” in the mdf box it has more bass then the whole setup, it is strange.
35 second tune-up Alex from Oz Full Range 65 22nd January 2010 08:42 AM
Jazz tune. GK Music 5 7th October 2008 11:57 AM
Bogen MX-60a tune-up apehead Tubes / Valves 4 28th December 2007 11:07 PM
Recognise this tune? Circlotron Everything Else 2 6th November 2007 12:29 AM
de-tune a SMPS Lostcause Power Supplies 4 30th January 2007 09:42 AM
Page generated in 0.10127 seconds (79.14% PHP - 20.86% MySQL) with 10 queries
