Old 15th February 2006, 10:52 AM   #1
Glen1 is offline Glen1  Australia
Default Sub design - need a little advice
Hi Guys,
I took the plunge a little while ago and built a sub using a Peerless 12" XLS 830500 driver in 47 litre ported box with a 90 mm port 75 cm in length ported to the front. The box is made from 32 ml mdf and I have a 14" square room. I'm using a 180 wrms plate amp to run the sub. I have found that this design allows the response to go really low but at times doesn't have the 'punch' I desire. The amount of bass produced is fine and the low end response seems pretty good but I'd like the sub to have a bit more dynamic 'punch'. I have tried it in a smaller 38 litre box with a 90 mm port 50 cm in length and this seemed to have a little more 'punch' but the bottom end just wasn't there. I've poured over Winpro for hours but as this is my first attempt I'm looking for a little advice.
Ta,
Glen
Old 15th February 2006, 11:06 AM   #2
Did it Himself
richie00boy's Avatar
It would seem you like to hear a peaky bass. Stick with your bigger box and tuning (although I feel the vent diameter is too small) and play with the upper cutoff frequency and level to see if that helps. Failing that, build a parametric EQ, just one will do.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 15th February 2006, 11:35 PM   #3
JRace is offline JRace  Canada
Punch is most often Mid bass (100-500Hz approx).
What is your x-over settings, and what speakers are you using to suplement the sub?
Old 16th February 2006, 05:06 AM   #4
Cross over is 80 hz and I'm using Epos M22 for mains and M8 for centre. Mains and centre run as 'small'. HT amp is HK AVR 635.
Old 16th February 2006, 05:59 AM   #5
David Gatti's Avatar
Have you tried stuffing the port for a sealed enclosure response?
It may be a group delay or room-integration issue that could be helped with 12dB rolloff. An easy experiment worth trying.
Class D Design needs your Advice alijoorabchi Class D 6 29th April 2007 10:09 PM
Advice needed for amp design gpond Chip Amps 3 29th August 2006 05:30 PM
Advice needed for amp design ifrythings Solid State 26 13th May 2006 01:17 PM
PCB Design problem.. Pls advice xitronics Everything Else 5 29th October 2005 05:19 PM
Page generated in 0.07448 seconds (73.47% PHP - 26.53% MySQL) with 10 queries
