Hey all--
Anybody out there with either of these amps (PE #300-806 and #300-808) care to measure standby and active idle current for me? I'd like to know whether it makes sense to future-proof by getting the 1000W, or if I'll just be blowing a ton of standby current compared to the 500W without ever really needing the 1000W in my current setup. Also, they list efficiency as 75%/86% (500W/1000W, respectively), but is that at max output power? Is it simply max efficiency (like it's 86% efficient at 100W output but then it goes into the toilet after that)? If I had the equipment, I'd do these kinds of tests for the sake of the DIY community, but I'm not going to drop >$100 on a 1000W dummy load just for that. Maybe next time I'm at the surplus store... Anyway...thanks for any help you can provide... --Greg |
#2 |
Efficiency is usually rated at full power output yes. It's also usually the same efficiency at any power level.
DIYaudio for President ! |
#3 | |
Also, isn't it possible that heating of the output devices would increase losses at full output power, too? Maybe it's not appreciable, but I'd like to know... Also, I just wanna know how much this thing will burn standing still, which is something an efficiency number will not tell me. I guess reading National,Hypex,Tripath datasheets have spoiled me for getting all the information I need... --Greg |
#4 |
If you use the 'auto on' feature, that turns the sub on when it gets a signal, that should lower standby current to just a few milliamps. Whatever the number though, the standby current would be the same for the big amp as the little one. Larger amps are usually more efficient, because they have increased cooling at lower volumes, but its not a huge effect.
peace, sam |
#5 |
Yes it's an overly simplified view. Yes there's fixed losses and class A power so not efficient at lower levels. Devices usually have more losses at higher output levels, but that's where they calculate efficiency.
I guess to know the standstill current and check the efficiency curve, you'll have to measure it yourself...
#6 | |
I may test it when I get one, but for now I will trust the response I got from PE which says that standby current is <10W. This seems pretty good, as I've seen specs on cheap 1kVA toroids that have magnetic losses of >20W unloaded. --Greg |
#7 |
Yeah I'm a future engineer myself so I understand you.
I would like to help you further but there's rarely as much information out as we would like to have in the audio market... The subjectivity of audio keep mostly all objective documentation hidden. We would all love to have those 7 pages specs sheets for every audio part like they give us about a simple 2N3904...
| Tang Band Subwoofers And 500w Plate Amp Fs | mg16 | Swap Meet | 10 | 8th November 2008 03:33 PM |
| FS: BASH plate amp 500W | dsrviola | Swap Meet | 1 | 26th December 2007 09:53 PM |
| FS: Keiga KGND-52100 1000w Icepower subwoofer plate amps | shokunin | Swap Meet | 3 | 7th October 2007 03:56 PM |
| PE BASH 500W Plate Amp | Viking552 | Subwoofers | 9 | 10th January 2007 06:56 AM |
| anyone ever run PE 1000W plate amp at 3 ohms? | derekwwww | Subwoofers | 1 | 29th July 2005 09:47 AM |
| Page generated in 0.09523 seconds (79.30% PHP - 20.70% MySQL) with 10 queries |
