The box= 2 or 2.2 F^3 (Sealed)
The application= HT/Music (blues, rock) The amp: Parts Express 240 watt plate The 12" choices: under $100 1. Ascendant Assassin 2. Dayton Quattro 12 3. Dayton Quattro 15 Any others I should consider? I want to stay under 100 no matter how much better the driver is! My orginal goal was 75, which basically limited me to quattros. This is for a friend and he only has $210. The amp is 120, that leaves 90ish for a driver. Thanks for suggestions! |
#2 |
I have the Quattro 15" in 2.5 ft^3 sealed. I think it works pretty well for minimal cash. The 12" is no cheaper and gives up a lot of extension, so unless space is at a premium I'd stick with the 15.
#3 |
Thanks for the input! What is your impression of the 15 quattro? For movies and music? How much power do you have going into it?
#4 |
300 W BASH amp. The 240 would be just fine, too.
I was going to write a long review, but I haven't had the benefit of experience with a bunch of other subs to inform my opinion so I'l keep it short. With the Quattro in a sealed box I know I'm not getting the very deepest (below 20 Hz) rumbles from movie soundtracks, but I'm getting a very satisfying bottom end for both movies and music. I'd have to fix a bunch of room rattles and resonances before I'd want any more bass extension than I'm getting. I'm still tweaking, but overall it has integrated into the system very well. I think the Quattro's a good deal for the money. Whether it will meet your needs (or you're friend's) is up to you! |
#5 |
Thanks sounds good. I am not sure if i should do the 15 in a 2.3 ft^3 sealed, or the 12 in 1 ft^3. Based on many of the posts i have read it seems that the 15 is better suited in a 3 foot enclosure, or 6+ ported. 6 is way too big for this application.
Would 3 ft vs. 2.3 make a huge difference? When i model the 12 vs. the 15 i get higher db's from the 12. I must have the parameters wrong... right??? Orginaly he wanted this: http://www.partsexpress.com/pe/pshow...number=300-635 But, I thought a DIY project would sound much better all around, and be fun too! Any thoughts on that sub, and would you agree that the quattro would kill that. Thanks for feedback! -M these are the two subs modeled in 1 (12) and 2.3 (15) orange is the 15... (spl) ![]() (gain) pics are too small, ohh well... |
#6 |
IMO, the 12" Quattro in a sealed box would roll off way too high to be a useful sub. In 1 ft^3, PE says the F3 = 60 Hz.
It would be pretty happy in 2 ft^3 vented. The overall response looks pretty similar to the 15" in 2.5 ft^3. I'd want to use a 'rumble' filter for movies or it might bottom too easily below 20 Hz. |
| OP AMP Selection | JBL Man | Chip Amps | 1 | 16th May 2008 06:42 AM |
| amp selection | spicer81 | Car Audio | 20 | 23rd February 2008 03:04 PM |
| USB DAC Selection | leggi | Digital Source | 33 | 3rd February 2007 09:24 PM |
| Help with selection? | Dougie085 | Chip Amps | 0 | 26th April 2006 07:27 AM |
| Amp Selection | Donaldo | Car Audio | 4 | 25th November 2004 04:59 PM |
| Page generated in 0.08451 seconds (81.59% PHP - 18.41% MySQL) with 10 queries |
