There is alot of decussion on port velocity and what is an acceptable limit. 17ms 25ms 34ms are what im hearing alot.
so a quick poll whats your peak velocity? What port and size? do you hear noise at peak? |
#2 |
Looks like 40 to 100m/s is What Im to expect in my car.
Cant hear port noise over Bass and normal rattling in my Car. In my house Im at 20 m/s and I cant hear a thing cause I dont usually Max my house system out enough to get full SPl's
subs rule |
#3 |
my port velocity.... 0m/s
currently sealed, going with passives in the future. collo did a thread about port velocity you can find here: Flared ports and turbulence I'd agree with vetkilr that in a car port noise becomes far less of an issue, but I havent done any actual tests... I just know I've heard quite a few ported boxes in cars that chuffed when you listened to them 2 feet away through the open trunk. With everything sealed up and inside the car, rattles were the #1 problem and the sound of port chuffing was inexistant
The golden rule of DIY: Build nice, or build twice! |
#4 |
With one of my basscabs I was able to here the portnoise around a simulated 31 m/s (it was probably a little bit higher tho), while the SPL from the speaker was far beyond common house use.
With the mid and high into the mix the problem was solved. Since then I use 30 m/s as a limit for PA and 20 m/s for hifi and alike. Wkr Johan |
#5 |
Hey BassAwdyO
Wondering if you're gonna order one of those 91 dB/1m/1W woofers from Ascendant? IIRC you said you wanted something >90 dB/1m/1W
DIYaudio for President ! |
#6 |
no plans on buying any woofers for a while here...
My next set would be some 18" pro drivers with hopefully better than 95db@1w 1m
#7 |
Some Aurasound stuff then I guess...
#8 |
0m/s
| volume velocity | bigcatdairy | Full Range | 10 | 3rd November 2008 08:43 PM |
| Help with Velocity VD-504 | Speeed3 | Car Audio | 2 | 9th March 2008 02:52 PM |
| Port air velocity | alexcd | Subwoofers | 41 | 28th August 2006 06:03 AM |
| what the max Air velocity of bass reflex port? | Audist | Multi-Way | 4 | 7th February 2005 08:43 PM |
| Page generated in 0.08683 seconds (79.15% PHP - 20.85% MySQL) with 10 queries |
