Hi
I am planing on building a sub for useing it for home theater and music with a bpa200 amp. Will this VISATON W 300 S 8 OHM be suitable??? In a vented box, what will be the best F3 ? Here is the T/S : W 300 S 8 OHM --------------------------- Rated power 150 Watt Maximum power 200 Watt Nominal impedance 8 Ohm Frequency response (-10 dB) fu - 4200 Hz (fu: Lower cut-off frequency depending on cabinet) . Mean sound pressure level 92 dB (1W/1m) Maximum cone displacement 28 mm Resonance frequency fs 23 Hz Magnetic induction 1,1 Tesla Magnetic flux 1400 µ Weber Height of front pole-plate 8 mm Voice coil diameter 5 cm Height of winding 1,85 cm Cutout diameter 28 cm Net weight 4,5 kg D.C. resistance Rdc 6,7 Ohm Mechanical Q factor Qms 1,65 Electrical Q factor Qes 0,42 Total Q factor Qts 0,33 Equivalent volume Vas 340 l Effective piston area Sd 507 cm2 Dynamically moved mass Mms 57 g Force factor Bxl 11 T · m Inductance of the voice coil L 1,8 mH Thanks |
#2 |
Did it Himself
The box will be pretty big (relative to what I call big, which is bigger than 60 litres) for vented.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
#4 |
With a box max 70 liter i will be ok but i think the F3 is not the suitable for a home theater usage.Is it?
Thanks |
#5 |
Did it Himself
With a 70 litre limit you are going to struggle to get a low enough F3 for anything, and the response in a vented box at least will be very peaky.
This is a job for a sealed box and Linkwitz Transform.
#6 |
Hi richie00boy
Thanks for the help.I think i will go with a beter sub.Have a look at this infinity.The only disadvantages is it coasts 50euro more than the visaton and i am afraid that the bpa200 will run hote with a 4ohm load.I think this one can go 20hz F3 in vented. Kappa 120.3se 12" Woofer VOICE COIL DC RESISTANCE: REVC (OHMS) . . . . . . 3.56 VOICE COIL INDUCTANCE @ 1 KHZ: LEVC (MH) . . . . . . . 2.13 DRIVER RADIATING AREA: SD (IN2) . . . . . . . . 76.11 SD (CM2) . . . . . . 491.00 MOTOR FORCE FACTOR: BL (TM) . . . . . . . . 15.51 COMPLIANCE VOLUME: VAS (FT3) . . . . . . . . 1.96 VAS (LITERS) . . . . . 55.61 SUSPENSION COMPLIANCE: CMS (ìM/N) . . . . 162.44 MOVING MASS, AIR LOAD: MMS (GRAMS). . . . 193.00 MOVING MASS, DIAPHRAGM: MMD (GRAMS) . . . 186.74 FREE-AIR RESONANCE: FS (HZ) . . . . . . . . 28.43 MECHANICAL Q: QMS . . . . . . . . . . . 6.82 ELECTRICAL Q: QES . . . . . . . . . . . . 0.51 TOTAL Q: QTS . . . . . . . . . . . . 0.48 MAGNETIC-GAP HEIGHT: HAG (IN) . . . . . . . . . 0.39 HAG (MM) . . . . . . . 10.00 VOICE-COIL HEIGHT: HVC (IN) . . . . . . . . . 1.46 HVC (MM) . . . . . . . 37.00 MAXIMUM EXCURSION: XMAX (IN) . . . . . . . . 0.53 XMAX (MM) . . . . . . 13.50 Thanks |
#7 |
~50L sealed, 100L reflex - port tuning 20 to 23 Hz. |
| Page generated in 0.10426 seconds (71.54% PHP - 28.46% MySQL) with 10 queries |
