Old 5th February 2006, 03:01 AM   #1
jp88 is offline jp88  United States
Default box for 12w3
alright here is the story. I have a couple of jl audio 12w3s laying in my shop. I am thinking about using one of them for a powered sub along with a dayton 240 watt sub amp. I am currently building a set of dayton budget hme theater speakers for my sattelites. (I have a thread about these in loudspeakers).
Now to the meat of my question. How would one of these 12w3s do in a 2.5 cubic foot ported box tuned to 23 hz. I have looked at it on winisd and it looks pretty decent but I am no expert by any stretch.
any suggestions are not only welcome but would be greatly appreciated.
WHAT
____________
Old 5th February 2006, 08:44 AM   #2
A 2.5 ft3 sealed box with normal daming will sound a heck of alot better then a ported box of that size. If you were to go ported, the box would have to be 5.7 ft3 with a port 4" diameter and 9" long with normal damping.
Old 5th February 2006, 01:52 PM   #3
looking at a comparison of this subs response in a 2.5 cube sealed and a 2.5 cube ported tuned to 23 hz on win isd it looks like the ported would go alittle deeper. the -3db for sealed is 34 hz the -3db for ported is about 28 hz the ported does have a small 1 db hump from about 50 to about 60 but seems pretty smooth. Jl calls for a 1.25 cubic foot sealed box and a 1.75 net cubic foot ported box tuned to 30.8 hz please explain to me why the sealed would sound better. I am not extremely familiar with ported boxes but I realy want to learn more. I am also going to use this primarily for home theater (and some music) but I want very good low end. My satelites should be pretty good down to about 85 hz. I also want to keep the enclosure under 3 cubes gross including the plate amp. I realy want strong bottom end and if this wont work I may consider selling my w3s and buying something different like possibly a dayton titanic 10 mk3
WHAT
____________
Old 5th February 2006, 05:28 PM   #4
CFC is offline CFC  United States
I may be wrong, but the fact that there is a 1dB hump at 50/60 Hz, essentially means that on the graph, your -3dB point, is now at -2dB (but you can simulate how the response will be with a crossover).
CFC
Old 6th February 2006, 01:05 AM   #5
I went back and plotted both together and even using the -2 for the sealed a s the -3 point the ported does 31 hz at -2 db and the sealed does 37 hz at -3 db. Am I missing something? Please advise I would like to eithers start building an enclosure or put my 12 w3s on ebay. would I be better off with a 10 inch titanic in its optimum ported box than the 12 w3 in 2.5 cubes? would the w3 sound better in a 2.5 cube sealed box than a 2.5 cube ported box? if so why? please advise....
WHAT
____________
Old 7th February 2006, 03:46 AM   #6
simon5 is offline simon5  Canada
Strong bottom end and box under 3 cu.ft gross ?
The high Vas of the 12W3 isn't helping you on this.
I suggest you this :
http://www.partsexpress.com/pe/showd...number=295-466
And this :
http://yellow.mynethost.com/~bv12636...6fc0b7d005a491
Build a 2 cu.ft internal net box with one of those passive radiators and add 250 grams of mass to the passive radiator.
DIYaudio for President !
Old 8th February 2006, 01:13 AM   #7
And this :
would this be much better than a dayton titanic 10? I notice dayton specs a 1.4 cubic foot box tuned to about 27 hz. If I am going to purchase another sub I would like to stay as small as possible without losing too much. I don't have a very large living room and don't want to make my neighbors too angry. What I realy want to know is
1. will the w3 do decent in 2.5 cubic feet. ( the consensus seems to be no)
2. would a titanic 10 in a ported box meet my requirements?
3. would a titanic 10 in a ported box be a lorge improvement over a 12w3 in 2.5 cubic feet ported or sealed?
I apreciate the recomendations so far.
WHAT
____________
Old 8th February 2006, 06:41 AM   #8
Titanic 10 is an old design, some found it to be noisy. If you plan to crossover very low, maybe it's not an issue for you.
The woofer I showed is a 12" with lower Fs so you'll have more deep bass.
I could do the same thing with the Titanic 10, but the price is high compared to this new better and larger woofer.
27 Hz is not deep bass IMO, if it's enough for you then go for it, for sure you can build a really small box with a Titanic 10.
If you want to go with those 12W3, just build a 2.5 cu.ft sealed box, you'll get a nice 0.707 Butterworth alignment.
Old 8th February 2006, 09:26 AM   #9
westend is offline westend  United States
The box sizes suggested by JL are smaller, probably to better mate with the suspension of the driver. They will work in the box sizes that you have plotted in Winisd. To ask which is best is hard to answer as a lot has to do with your listening habits. I would recommend building the sealed box with the JL sub you have and see if that meets your requirements. A sealed box is a fairly easy project and I am going to guess it will be enough bass for your living room.
If you're going to build a more musical or lower extending sub I would suggest going to a 12" or 15" sub and not using a 10". The box sizes will not be that much more for the larger drivers and the benefit in sound will be a good trade off for the additional space used.
Old 10th February 2006, 06:38 AM   #10
Send a message via AIM to dan87951
Nice sub
Page generated in 0.13507 seconds (84.44% PHP - 15.56% MySQL) with 9 queries
