Old 3rd February 2006, 04:45 PM   #1
Default Check over my AV12 design
Before this gets built I wanted some advice if the design is ok im such a noob it's not funny lol
ae speakers Av12 driver
PE 500W amp
142L ported enclosure tuned to 18hz
two 4" flared ports 37.94 inches long
I plan to have a simple box design with the driver and ports on the front baffle. With the box braced heavly. I was going to buy precsion flared ports from PE and use the flared ends on some pvc pipe which will have to bend to fit inside enclosure.
If i increase enclosure to 160l the port will be 33 inches instead of over 37, better?
is this project doomed for failure or is it ok to go ahead?
stick to this or something else?
Old 3rd February 2006, 07:35 PM   #2
simon5 is offline simon5  Canada
I know passive radiators are more expensive, but this box is large for an AV12.
It will work but it might be slightly boomy.
DIYaudio for President !
Old 3rd February 2006, 07:37 PM   #3
it doesnt have to be that large but ports are very long no matter what size.
I would use PR but funds very tight.
what would be a good comprimise using ports?
Old 3rd February 2006, 07:47 PM   #4
If I was to use 4cf which is 113L could I get away with one 4" flared port?
this is the design recomended so someone must of built it?
please help I have allready bought the av12
Old 3rd February 2006, 09:50 PM   #5
Collo is offline Collo  Australia
Collo's Avatar
Send a message via MSN to Collo
A four inch port with Precision port flares each end (30mm radius) is good for 17 - 18 m/sec. before you get audible chuffing.
Use a design program that lets you check peak port velocity (for example WinISD). If the velocity is higher than this, you'll need to reconsider. A single 4 inch port is usually what you use for a 10 inch driver. I suspect that you will need a pair
regards
Collo
Ports rule!
Old 4th February 2006, 12:50 AM   #6
Ok been playing about in winisd how does this sound?
av12 with 250w
104L enclosure tuned to 18hz with one 4" flared port which gives port velocity under 35m/sec
Im happy with this but will 250w be ok?
Old 4th February 2006, 04:32 AM   #7
Collo's Avatar
Are you using WinISD or WinISD Pro? The help file in the first one recommends a max speed of 34 m/s. The pro version (still free) has better graphs and has dropped the recommended speed to 17 m/sec.
I'm using the pro version and its database comes with a driver named "Stryke Audio SAE1204". I'm not sure if this is the same driver - if not, maybe you could attach your project file and we can have a play around with it.
On the off chance that the driver is correct, I ran your figures and found:
- Peak velocity is 33m/sec at about 16hz. This falls below 17 m/sec once frequency is above about 23hz. What you are banking on is that there will be be very little full power content below 23hz. This is probably a reasonable assumption.
- Cone excursion fine above 16hz - again reasonable.
- Pipe mode resonance - around 270hz - OK with the low-pass that the PE amps have.
Ports rule!
Old 4th February 2006, 05:43 AM   #8
I have read 34-35m/sec alot of places im using winisd pro.
I would think it is impossible to get under 17m/sec with av12 and 250w no matter what i do it doesnt go anywere near that low, not without insane port lengh
Old 4th February 2006, 05:46 AM   #9
here is my project file for winisd pro
http://philliphatton.homestead.com/files/av12.wpr
Old 4th February 2006, 06:36 AM   #10
If i was to use this port
http://www.nexxia.co.uk/Hi-Fi&TVacce...port_tubes.htm
which says 115mm Inner diameter (4.5inch) that would give me 27m/sec at 15hz
and only 33 inches long which isnt much in a bend
PSU Design Check Please ANDYLASER Power Supplies 14 15th July 2010 11:42 AM
New Here. Will you check me design? SightSeeker1 Subwoofers 19 13th April 2006 03:59 PM
AV12 Design Aggravation BAM Multi-Way 13 28th January 2004 03:27 AM
Check my first design, 6900/2A3 IT arnach Tubes / Valves 62 24th November 2002 09:44 AM
Page generated in 0.10345 seconds (76.33% PHP - 23.67% MySQL) with 11 queries
