Need help designin a box for a Kicker 0512L72
Old 30th January 2006, 11:53 PM   #1
vetkilr is offline vetkilr  United States
Default Need help designin a box for a Kicker 0512L72
I was lookin for specifics to help someone,but all Kicker gives is a sealed and ported specs and not any general info in thier Manual.
On thier site it says the 06 which is rated the same as my 05:
Resonance frequency[fs],HZ = 34.0
Total Q-factor[qts] = .513
Equivalent volume[vas],ft3(l) = 2.2(62.5)
My trunk can fit around a 32X13X13 give or take a inch.
Ive had Bandpass in the past and love it........I looking for the most Boom for the Space I have.........I was wondering if 2 speakers in a sealed box would hit harder or one with the correctly designed box would hit harder.
I listen to technoBass notes/Rap and alot of others includin country..hehehe
But I like to have really low bass hittin capibility without losin alot of clarity for my country days.
Thankx for all the help guys.
Joel
subs rule
Old 1st February 2006, 04:20 AM   #2
simon5 is offline simon5  Canada
Most boom? Then go for a ported or a bandpass enclosure...
Do you have the Xmax?
DIYaudio for President !
Old 1st February 2006, 03:41 PM   #3
Xmas=
.52in/13mm
Thankx
subs rule
Old 1st February 2006, 07:49 PM   #4
I think your box is too small to go with bandpass...
I'd go with a ported enclosure of 13x13x32 tuned with a single 4" diameter full length precision port.
Old 1st February 2006, 08:44 PM   #5
Whats a 4" full length precision port??
subs rule
Old 2nd February 2006, 07:23 AM   #6
I going to make a 2 piece box and make it 6th order!!
2 cubes each side........one to 35hz the other to 78hz.
Its just killin the ported box down low and up top by 3-5dbs and has a nice slope.....
What do you think???
Any programs out there to design or draw your box out good as Ill need to put it together somewhat in my trunk
subs rule
Old 3rd February 2006, 08:40 AM   #7
13x13x32 = 11.5x11.5x30.5 assuming you're using 0.75" walls.
That's 2.3 cu.ft internal net. Now remove driver volume, braces and port volume, you're probably at 2 cu.ft.
There's no way you're gonna fit 4 cubes in that space.
To design a box, you could use a CAD program...
A full length precision port is this :
http://www.partsexpress.com/pe/showd...number=268-352
Old 3rd February 2006, 08:53 PM   #8
Are there any free Cad Programs out???
I was thinkin about makin a 2 piece box and semi buildin it in the trunk
Looks like it is best just to build a ported box at around 40-44hz with a subsonic filter on it for 30-35hz with a 24db cutoff to avoid over excursion under that ........
What you think??
subs rule
Old 3rd February 2006, 11:26 PM   #9
Bah, I was thinking tuning it with a precision port like I've showed you. That would tune it around 27 Hz then add a subsonic at 25 Hz.
Old 4th February 2006, 08:51 PM   #10
doin that I have a major cone excursion at 47-67hz at 750watts or more.
The rms is 750........I was tryin to get around 900 safely without over excursion???
subs rule
Need help designin a box for a Kicker 0512L72Hide this!Advertise here!
Kicker 600.1 mike49504 Car Audio 3 25th March 2009 04:10 PM
Kicker L5 in a 1.75 box skooter Car Audio 4 16th October 2008 01:54 AM
Kicker L7 skooter Car Audio 5 25th September 2008 11:36 PM
Kicker 500 si stormtrooper Car Audio 0 25th September 2006 01:20 AM
Kicker: KX vs. SX NaftaliG Car Audio 0 11th December 2004 08:21 PM
Copyright ©1999-2017 diyAudio
