Old 28th January 2006, 11:07 AM   #1
toenail is offline toenail  United States
Default Winisd port configuration
Curious about interpreting the port recommendations from Winisd Pro alpha. Increasing the number of ports increases the length needed. Is this new length to be divided by the number of ports or is each of the ports supposed to be this new length? Trying to lower rear port air velocity and avoid "tuned pipe".
Old 28th January 2006, 11:12 AM   #2
Did it Himself
richie00boy's Avatar
Each vent needs to be that suggested length.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 29th January 2006, 11:22 AM   #3
Thanks much
Old 30th January 2006, 01:23 AM   #4
simon5 is offline simon5  Canada
As you can see, you have to make a compromise.
Putting more ports lower the strength of the air spring so you need to make every port longer than before.
DIYaudio for President !
Unibox/WinISD Port Size Discrepancies HTRookie Multi-Way 2 30th September 2007 06:34 PM
issue WinISD port length Qes/Pe! Amit_112dB Subwoofers 4 4th August 2007 06:26 AM
Port length in WinISD? Marsh Subwoofers 10 1st July 2007 07:42 PM
WinISD vs. UniBox on port tuning dscline Subwoofers 3 27th September 2006 05:39 PM
newbie question.WinISD and port tubes PTM Multi-Way 4 31st January 2005 08:55 AM
Page generated in 0.06315 seconds (71.14% PHP - 28.86% MySQL) with 10 queries
