I recieved two free subwoofer drivers from a friend. Through a lot of searching, I got the manufacturer and they sent me these specs...
Fs= 16 Hz VAS= 8.1 ft^3 Qts= 0.208 Qes= 0.217 Sd= 51.1 in^2 xmax= 0.23 in Znom= 4 ohm DCres= 3.6 ohm PMax= 200W RMS I have one suggestion of a sealed 1-2 ft^3 cabinet with a 120W plate amp. What would you build with this for music and minimal HT? |
#2 |
The Vas is quite high, I would build a cabinet larger than that if you can. Those are 10 inchers?
Parameters seems wrong, or efficiency is really low... Xmax is low also... Good luck!
DIYaudio for President ! |
#3 |
Parameters appear correct in bassbox pro (at least not obviously impossible)
I came up with a 3.5cuft vented box for the pair with a single 4'' x 10'' long port. |
#4 |
Volenti...think it would be okay to make two single driver subs. Maybe one per side (in a big room), or for use in two different systems?
I don't need anything to shake the house...just the filling in of the lower registers for a fuller sound. Thanks for the help! |
#5 |
What are you crossing them to?
Are you going to use amplifier bass management to cross to them? Or do you have pre-out / power in on your amplifier, so you can put an active crossover in there? |
#6 |
I would just be using a plate amp to start. So, onboard, no active crossover...yet. That would be down the road. Maybe I will use one driver for the plate amp setup. Then hold one for playing with an outboard amp and active crossover setup.
#7 |
What I was getting at was integrating it with your other speakers. How low do they go?
I've never tried simply adding a sub on top of an existing system (because I've always had an AV amp with bass management). If this is a replacement sub in a sub/satt system I suppose it is a straight swap. |
#8 |
Sorry...misunderstood for my part.
The existing speakers go down to 70Hz. It is not replacing another sub. This would be the first in the system. |
#9 |
and can you put a crossover in between your current pre/power amp?
I'm thinking dual sealed subs, active stereo crossover: >200Hz to existing amplifier <200Hz + Linkwitz Transform to new plate amps or chip amps. That'll be about as 'musical' as you can get. |
#10 | |
| I want to try and build my own DAC | gareth | Digital Line Level | 3 | 3rd July 2009 03:20 PM |
| ZV9 build | ingi | Pass Labs | 8 | 6th August 2006 02:40 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Page generated in 0.10597 seconds (75.93% PHP - 24.07% MySQL) with 11 queries |
