Placement of PR on a sub box
Old 16th January 2006, 06:57 PM   #1
Stantob is offline Stantob  Sweden
Default Placement of PR on a sub box
I am planning to build a sub with the classic Peerless XLS and a passive radiator. PR is new to me and I have searched the net to learn. But one thing remains unsolved to me. I have seen solutions where the passive element is facing all directions.
Doesn't this have any influence on the construction? Phase problems? I want to place the PR on the same side as the main element, pointing downwards.
Does the distance between the elements have any importance?
Thanks!
Old 16th January 2006, 07:05 PM   #2
simon5 is offline simon5  Canada
A passive radiator is usually VERY heavy so pointing downwards is usually a very BAD idea.
If you crossover low, the PR can be anywhere, even behind.
DIYaudio for President !
Old 16th January 2006, 08:14 PM   #3
Didn’t think of that! Is it the same problem with XLS drive element pointing down? A solution could be using a vented system. A long vent should not be a problem in my design.
Old 16th January 2006, 08:26 PM   #4
You can have the XLS pointing down if you have less than 5% of sag.
It's mostly a problem with PRs, but some drivers can't achieve less than 5% of sag too.
You can't use a frontfiring PR?
Old 16th January 2006, 09:36 PM   #5
It is more of an aesthetical problem. I want the speaker to be "invisible". Two 12" elements poining at your fase is not.
Old 16th January 2006, 10:21 PM   #6
But the woofer under and the PR behind, as long as you doesn't put the subwoofer too close to a wall it will be ok.
Placement of PR on a sub boxHide this!Advertise here!
L pad placement.... Big_Bill Multi-Way 6 22nd July 2009 03:21 PM
Placement lpd Planars & Exotics 0 20th August 2008 11:39 PM
Opt placement Niila Tubes / Valves 1 20th March 2008 07:04 PM
sub placement chainenoble Subwoofers 3 13th October 2006 03:45 AM
