help with design SPL box (subwoofer T\S data inside)
Old 11th January 2006, 11:04 AM   #1
Astro Power is offline Astro Power  Israel
Post help with design SPL box (subwoofer T\S data inside)
Hii all...
I have power acoustik SQ-12 subwoofer...
i want to build the best box for this sub....to get the maximum.
the T\S parameters :
12 inch subwoofer
2' dual 4 Ohm Voice coil.
600W rms
SPL_____92dB
QTS_____0.4546
QES_____0.49
QMS_____5.82
VAS_____1.52 Cu. Ft
FS______32 Hz
Xmax____0.36 inch
it is for my vehicle..
my size limit of the trunk is :
width: 35.43 inch
height: 19.68 inch
depth: 19.68 inch
thanks
tamir
Old 11th January 2006, 01:22 PM   #2
Volenti is offline Volenti  Australia
1.8cuft, port 4'' by 9'' long. street boomer (performance)
1.8cuft, port 4'' by 18'', SQ, bass extension.
1 box with 2 port choices, you can choose whichever works best
[edit] ultimate spl option; Bandpass.
rear (sealed) chamber 0.7cuft, vented chamber 2cuft, port 6'' by 4'' long, sub is mounted with the magnet in the vented section (cooling), note this is an SPL only option, ~6db louder than the street boomer, will sound very one notey/boomy with music.
Old 11th January 2006, 01:59 PM   #3
thanks !! in the end of the building i will put some pictures of my work !.
edit: how u desing this box ? with winisd?
tamir
Old 11th January 2006, 10:42 PM   #4
BassBox Pro, commercial software with more features than winisd, I use it fo my work.
help with design SPL box (subwoofer T\S data inside)Hide this!Advertise here!
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
Copyright ©1999-2017 diyAudio
