Old 3rd January 2006, 11:50 AM   #1
enter is offline enter  Greece
Send a message via MSN to enter
Default Magnat Xtc 300
I am thinking about this good price sub magnat XTC 300 for a home theater use and so i run a simulation with it.The problem is tha i dont have all the T/S parameters and i would be very happy if someone knows anything about them.
The sub:
DIN Durchmesser 300
Ulower cut-off frequency 19 Hz
upper cut-off frequency 1500 Hz
Nominal Power handling 250 Watt
Max. Power handling 500 Watt
Impedance 4 Ohm
soundpressure level 92 dB
Fs 30
Vas 81
Qts 0,31
Qes 0,33
Qms 8,0
Xmax 16
Specials Solid screwed aluminium die cast basket Nickel coated terminal plug Double spider 2.5” high power capton voice coil ighly flexible rubber suspension for 14 mm linear excursion (XTC 380 - 18 mm) High power multi magnet system
Old 3rd January 2006, 11:58 AM   #2
Default MAGNAT xtc 300
And the graph:
Old 3rd January 2006, 04:53 PM   #3
Any coments about the simulation ?does it look ok? What about the sub?Has anyone used this sub for any use???
Old 3rd January 2006, 06:43 PM   #4
chops is offline chops  United States
chops's Avatar
I don't know, but being down -22dB @ 20Hz doesn't sound like a good start for a subwoofer system.
Charles
Old 3rd January 2006, 09:50 PM   #5
Yes your right but i didint expect beter Considering the price from this sub.With my little expirience i think that the F3=40Hz isint so bad or is it??? I traid to for a lower F3 but i couldent do somthing beter in vented. Is it posible to do something els to improve it?
Old 3rd January 2006, 10:27 PM   #6
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
looks like a small box and a high rolloff. What does the excursion graph look like at 250W? I would try for a larger box and lower tuning. Something like 60L and 25-30Hz?
The power of Science compels you!
Old 4th January 2006, 12:11 AM   #7
The excursion graph showes nothing because i dont have the Sd parameter of the sub.Is there a way to find it ???I couldent make the grap linear for a biger box and lower tunig. Maybe i am
mistaking somewhere
Old 5th January 2006, 04:56 PM   #8
DcibeL's Avatar
You should geta good idea for the area of the cone (Sd) by measuring the diameter of the cone and using the area of a circle formula. I think it is area = pi*radius^2.
Old 5th January 2006, 08:43 PM   #9
DcibeL's Avatar
I had a look at several 12" drivers and they look to be about 500 cm^2 for Sd.
Old 6th January 2006, 03:17 PM   #10
Thanks so mutch for your interest and help but i think it's not worth of risking with this kind of sub that doesent have all the T/S parameters and i will try constructing a box with the infinity kappa 1203 se. It is about 50 euro more expencive but i think it is beter than this magnat.Is it??
Although the magnat(or a sub like magnat) doesnt have all the T/S neaded it is a real chalenge for me to make it sound good but i don't have the big expirience to do it and thats the reasone i posted this graph.
Magnat Interior Loudspeaker pelanj Multi-Way 1 28th October 2008 09:37 PM
Magnat Plasma MP-02 Electrode and other maxitu1 Planars & Exotics 3 16th April 2007 07:36 AM
Dahlquist DQM-7 vs Magnat All Ribbon 5 manitoulin Multi-Way 0 11th August 2004 02:31 PM
Page generated in 0.08717 seconds (86.41% PHP - 13.59% MySQL) with 11 queries
