gonna build my first enclosure ever...just curious, once you get all the pieces cut, what do you use to hold it together? nails? glue? silicon to seal it from the inside? what works best?
if its important, its going to be the tangband neo 6.5" sub |
#2 |
I usually use glue to keep the parts together, and sometimes screws to get the construction a bit stronger. I think nails aren't suitable to build a strong, solid enclosure. Finally, to be sure that the box is airtight, I use silicon kit to fill up openings.
best regards Erwin |
#3 |
Wood glue all the sides togather that you want to be perminant. Clamp the pieces when you do this, they need to be dried overnight.
Once you have all the sides glued then you drill holes for the size of screw you want to use. Go with what ever screw size you feel will not hinder the boxes strength. Basically I would never go with any thing bigger then 1/3 the width, including the threads (not the head) then the thickness of board used. You should always put some thing in to make sure the seal stays unless the pieces fit togather well. It will be a problem is there is any stress pulling on the wood glue, wood glue is not amazingly strong. You CAN use an air nail gun on really small speaker boxes that are cheap, perhaps not perminant. Nail gun nails make speakers look poor. When I say nail, I am talking about the ones that are barely bigger then a sewing needle. On subwoofers sinking some screws is a MUST. The bigger the box the more. I would say probably every three inches on powerful suboofers. The little ones will be fine with much less, just enough to have some support at the ends and the quarter length marks. After you have got your wood glue dried and screw sunk it is time for silicon! On the inside give a nice assuring coat of silicon all around where the cracks would be if it was not for wood glue. On the outside you are going to be all about athstetics, that is up to you. |
#4 |
Wood glue, if properly applied and clamped tight enough while it dries, gives a stronger bond than the wood itself. The wood will fail before the bond does. I predrill all my holes, and use drywall screws no more than 6" apart to hold everything together tightly while the glue dries. I use polyurethane glue, because it has a tendency to expand and fill small gaps from the cuts not being perfect. This can make caulking afterwords unnecessary.
#5 |
For the cost of a decent set of clamps, you can by an air nail gun in the "tack" or "trim nail" size. They offer no benefit for the permanent securing of the box. HOWEVER, they are PERFECT for establishing the contact between surfaces so that the glue can make the best bond. Further, unlike clamps, one can complete the entire box in one sitting. There's no issue with the clamps interfering with the next orientation of the box and application of the "next" side. Nail holes are easily filled directly after the first finish coat or sealing coat.
#6 |
interesting, chipco...i hadnt thought of that
honestly the idea of clamps seems real complicated, simply cuz u cant do it all in one sitting...i like the idea of a nailgun... why couldnt i use just a basic hammer and nail instead? and how would i go about securing two pieces of wood while im trying to nail them together? seems like a two person job, since i am new at this.... |
#7 | ||
Speakerholic
#8 |
ok i think i get it...you brace it against something on the bench and hold the other peice in your hand against it, and nail it while i hold it...seems like it would be hard to get it precise, unless maybe i am not envisioning it right...someone go video themselves doing it so i can watch...
also what does W.H.Y. mean? |
#9 |
If you try hand nailing your pcs, you'll know why it's not a good idea! That glue makes for a very slippery surface when first applied. Clamps give you the ability to adjust the placement of the pieces as you go. Nailing the pieces together with a brad nailer, etc, won't insure a good joint unless (unlikely) your stock is dead flat, 'cause the brad nails won't be able to press the joints flat. They can help in assembly though.
#10 |
Speakerholic
WHY = what have you. Meaning just find a way to make it work.
Always assemble your boards on edge so the bottoms are flush and use your fingers to line up the board along the joint. It's really not that hard but from time to time you'll have a Doh! moment. If it's more than you want sand out, you'll have to knock the board apart, bang out the old brad (nail with no head) and start again. Just practice on some scrap boards with no glue until you feel comfortable. Next thing you know you'll be doing it for other people. |
| Noob needs help building enclosure / x-over | Ettienne | Multi-Way | 3 | 27th March 2009 02:35 PM |
| Bass enclosure building question? | Doug Kim | Multi-Way | 2 | 11th April 2008 03:19 PM |
| building an enclosure | atnaat | Subwoofers | 16 | 28th June 2005 04:49 AM |
| Building a nice looking sub enclosure | grampi | Multi-Way | 8 | 1st December 2003 10:39 PM |
| Page generated in 0.11684 seconds (79.89% PHP - 20.11% MySQL) with 10 queries |
