Old 27th December 2005, 07:10 PM   #1
dscline is offline dscline  United States
Question Sealing a driver to the baffle
I'm building a sub based on two Rythmik Audio servo kits, installed into a dual chamber sealed box. The kits came with both a rubber gasket that completely surrounds the rim of the driver (see below):
as well as a thin gasket of foam rubber that can alternatively be applied to the box before mounting the driver. Since the foam rubber gasket was damaged in the box (it seems the weight of the driver ended up on a small portion of the gasket, causing it to be permanently compressed), I chose to use the much thicker rubber gasket.
Although I haven't yet drilled the mounting holes in my box, I did a quick test of the one of the driver/amp pairs, by placing it in the hole and simply holding down in place. However, no matter how much pressure I applied to the rim, I could still hear air leaking around the gasket at low frequencies. I realize I'm not going to be able to apply as much pressure as screwing the driver into place, but I'm concerned that it may still not provide a complete seal.
Does anyone ever use any type of caulking between the rubber gasket and the box? I'd prefer to find something that would help provide a better seal, but not have any adhesive properties that would prevent the driver from being easily removable.
Old 27th December 2005, 08:01 PM   #2
ejn327 is offline ejn327  United States
I used some butyl culk to seal in some drivers, but it makes it near impossible to remove.
With my subwoofer, I removed the culk tape and put gasket tape in its place. It works great and makes an air tight seal.
You can get a 50 foot roll for 5 bucks over at parts express
http://www.partsexpress.com/pe/showd...number=260-542
Old 27th December 2005, 08:20 PM   #3
Retsel is offline Retsel  United States
I have used pipe dope for my speaker drivers. Pipe dope is available at hardware stores and it is like clay but stays moist for a very long time.
Retsel
Old 28th December 2005, 04:12 AM   #4
I second the Parts Express gasket. I've used it on all my projects and really like it. They do sell it in more than one size.
Old 28th December 2005, 06:55 PM   #5
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
I have an Ascendant Audio Atlas subwoofer that has an almost identical rubber "gasket" around the edge. I didn't put anything on it to seal it and there are no leaks whatsoever. The rubber works quite well. For simplicity, would it not be easier to finish the sub using nothing, then if there are leaks you can take the driver out and add a seal.
The power of Science compels you!
Old 28th December 2005, 07:50 PM   #6
Send a message via ICQ to Mikael Abdellah Send a message via MSN to Mikael Abdellah
Here is what I use exclusively. It's some sort of butyl product too. Very sticky.
http://www.monacor.de/int/en/produkt...pr=EN&typ=full
Old 7th January 2006, 02:23 PM   #7
Just to follow up, I found a good product for this situation. I wanted something the consistency of Vaseline, but wanted to make sure that it wouldn't compromise my surrounds if any inadvertantly got on them. It seems the surround of my TC2+ drivers are rubber, specifically NBR. Based on the research I did, petroleum jelly is relatively safe for NBR (unlike latex rubber, used in condoms, which is severely weakened by petroleum products), though silicone is preferable (and even protects and extends the life of rubber). There is a very thick product called "plumber's grease" that is used to lubricate, protect, and seal o-rings and other components in faucets, etc. From what I've read, there's both petroleum based and silicone based plumber's grease. I found a small tube of it at Ace, though there was nothing to give any indication of what it's base was. After I got it, it SEEMED to me like it was petroleum based (silicone has a different feel). Since it's used in conjunction with rubber washers and o-rings, it should be fairly safe, but I still preferred silicone. So I found a small tub of "silicone plumbers grease" at Lowes.
Smeared it on the gasket where it comes in contact with my box, as well as the rim of the driver that inserts into the gasket. On one of my two drivers, it worked perfectly. The other one was fine around the gasket, yet still had some slight air noise at some of the screw holes at low frequency high excursion signals. Since the petroleum based product came in a tube and was therefore easier to squirt into a hole, I used it: removed the first screw where I could tell was leaking some air, put some of it into that hole, then screwed the screw back in. Then hunted down the next leak. After three screws, it was air tight! I have absolutely no sound at all during high excursion infrasonic tones.
Old 9th January 2006, 05:57 AM   #8
simon5 is offline simon5  Canada
Some people use weatherstripping tape, sticky on both sides.
Silicone isn't bad either.
DIYaudio for President !
Old 10th January 2006, 12:21 AM   #9
Celeste is offline Celeste  United States
Default plumbers greese
look for Dow Corning 111 silicone geese , its for hot water and steam valves. very heavy, I have seen it in 1 oz tubes 6 oz tubes and 14 oz sticks for a caulk gun.
Celeste
Old 10th January 2006, 02:16 PM   #10
If you use a foam of any considerable thickness, I'd recommend
it be low density, such as weather stripping foam. High density foam
if compressed too far under the screw points can exert too much stress on the frame at the points between the mounting screws. Could warp a stamped frame or crack a cast one.
Sounds like an amazing sub in the works.
Paint damage from sealing drivers with silicon, what to use for sealing drivers? DexterMorgan Multi-Way 21 12th February 2009 11:46 AM
Sealing enclosures dsavitsk Full Range 4 17th January 2009 07:13 PM
baffle driver location blue934 Multi-Way 2 19th February 2008 04:35 AM
what about sealing the enclosure? gnugear Full Range 2 9th October 2007 09:32 AM
sealing around drivers nobody special Multi-Way 4 6th February 2003 06:18 PM
Page generated in 0.10410 seconds (79.97% PHP - 20.03% MySQL) with 10 queries
